Results 1 to 7 of 7
Thread: E15 in Etec?
    Jun 2004
    long island
    E15 in Etec?
    I heard that the local gas stations will be switching from E10 to E15 soon
    Can I safely run my Etecs (300 G2 / 115) on it?
    thanks!
    Lake Coochiching, Ontario
    Nope
    Sep 2019
    Lake Keowee, SC
    I don't think all stations will carry only E15, at least not in our area. Some will be available but I don't think any outboard mfg has approved E15. If E15 was my only choice I would simply continue with the non ethanol I currently use.
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by Pulsare2400 View Post
    Yeah you shouldn't really even be running e10 in your etec now. Those and optimaxs don't do well with ethanol. Burns too hot and the engines are too lean
    Jun 2004
    long island
    Unfortunately, aside from buying race or aviation fuel, I don’t believe that there’s an alternative in the tri-state area
    I asked at a few marinas about the upcoming E-15 fuel
    They had no information
    I think that E-10 has been the only choice around here for the last 15 years or so
    Aug 2019
    Palmharbor
    You can add some opti oil premix to the fuel it will help!!
  7. Thanks doug7488 thanked for this post
    St. Pete Fl
    there is not an engine manufacturer out there currently that authorizes anything more than e10 in their engines. Any more than that, and they will not honor the engine warranty if that is found to be the cause of a problem. I would think that if the the manufacturers wont stand behind their engines with that fuel, it would be a bad idea to run it.
  9. Thanks doug7488 thanked for this post
  1. WTB: eTec & eTec G2 Core Injectors
    By InjectorService in forum Parts Wanted
    Last Post: 05-27-2020, 04:40 PM
  2. Why are ETec G2 H.O. Motors selling for less than the older Etec H.O.'s ?
    By Pachanga_rick in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-05-2016, 01:51 AM
  3. Replies: 4
    Last Post: 01-29-2016, 07:19 AM
  4. Difference between 2008 etec 200ho & 2011 etec 200ho??
    By coojac in forum Racer's Hangout
    Last Post: 09-02-2013, 05:43 PM
