Results 1 to 3 of 3
Thread: Mercury 2.5 FF Promax Spec
05-26-2022, 06:34 PM #15000 RPM
- Dec 2011
- united states
- 494
- 7
- 7
- 25
For Sale: 1998 matching #’s 2.5 200FF. It has been brought to 225PM spec. Has 14hrs on rebuild. If you know me, you know who built it. It’s done right. No expense spared. All original bores, all new internals. Rods and pistons all weighed & balanced. Has factory 225pm/260 exhaust divider, late model factory A32 225pm ECU, tested by Fullers Marine, factory 260 16amp lightweight flywheel with Simon Alternator kit with brand new belt. Brand new 16 amp stator, new rectifier, new NGK plug wires, new plugs, etc. Fuel system has been cleaned, VST serviced. Turn key. Freshwater only it’s whole life. Has a factory alien cowl, pan, skirt, with new stainless pan insert, added southco latches, and new decals. Has a couple scratches that can be buffed out but overall a very clean cowl. Midsection is a factory 2.5 280 bass can with single piston o/s trim (newer style with the plastic slides). Trim pump has brand new solenoids on it. Factory 2pc plate with factory 225pm tuner. Lower is a late model big window CLE, with the big skeg. Lower was just completely torn down and gone through. All new seals, bearings, etc. super fresh. Motor is super strong. Located in CT. Will sell complete for $8500 or part out as follows:
Powerhead-$4800
Cowl/pan/skirt-$900
Complete Mid-$1,000
Lower-$2,100
Trim pump-$250
PLEASE TEXT FOR PICTURES (845)-803-9987
seychellesboy liked this post
06-10-2022, 08:38 PM #25000 RPM
- Sep 2008
- charlestown, ri
- 296
- 10
- 37
did these come with the alien cowl in 98'?
06-13-2022, 05:19 PM #3New Member
- Jun 2022
- Boca Raton Florida
Mercury 200 Black Max with 26p Trophy Plus (max rpm is within spec?)
By CottagerGreg in forum Props, Setup, and RiggingReplies: 12Last Post: 06-03-2015, 09:31 PM -
Mercury CLE unit spec / repair manual
By aggiestckl in forum Technical DiscussionReplies: 1Last Post: 02-17-2013, 06:50 PM -
Mercury Tech: Compression Spec for 2000 Mercury 225 Optimax
By Stitch King in forum Technical DiscussionReplies: 5Last Post: 03-24-2010, 08:47 AM -
Question: Any place to find OEM Mercury Spec's
By Pachanga_rick in forum General Boating DiscussionReplies: 11Last Post: 04-26-2007, 12:56 PM -
Torque Spec. 225 ProMax Head???
By at100plus in forum Technical DiscussionReplies: 7Last Post: 03-25-2002, 11:48 PM
