Results 1 to 4 of 4
Thread: Sealing Pressure Treated Plywood
05-25-2022, 03:10 PM #15000 RPM
- May 2001
- Maine
- 979
- 35
- 41
- 169
I have the replacement trailer side platforms cut from 3/4" Pressure treated plywood (originals were 1/2") as recommended by a S&F Member, but I am wondering about sealing them especially the cut edge... Whats best... Thompsons water sealer, a good coating of marine oil base paint or what????
05-25-2022, 05:18 PM #2
If your plywood was KDAT (which I doubt) you can use anything. Standard treated is usually wet, sometimes really wet, and it is hard for an oil base to stick to it. I would probably use Thompsons. Theoretically you should not have to use anything as it has been pressure treated.
RockTeam Junk
05-25-2022, 05:41 PM #35000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
Use pressure treated end cut coating.
it’s the same stuff the use to pressure treat the wood, only you brush it on.
05-31-2022, 05:19 PM #45000 RPM
- May 2001
- Maine
- 979
- 35
- 41
- 169
I coated the cut ends with 3 coats of WoodLife Copper Coat, just wondering if I should coat the entire 7.5' x 1' section of 3/4" PT Ground Contact plywood with the WoodLife?
Don't use pressure treated plywood!?? really?
By billykissell in forum Fiberglass and Composites DiscussionReplies: 21Last Post: 07-17-2012, 12:11 PM -
treated plywood
By Riverratt in forum Fiberglass and Composites DiscussionReplies: 42Last Post: 06-08-2008, 02:45 PM -
Marine Plywood or pressure treated???
By apollo18 in forum General Boating DiscussionReplies: 8Last Post: 11-13-2005, 06:16 PM -
treated wood
By illMATTic in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 02-21-2005, 11:32 AM
