Results 1 to 4 of 4
05-21-2022, 10:20 AM #1
VST set up? How to add a regulator?
im thinking ahead here and with some of my mods i feel at bare minimum I should add an adjustable regulator to my VST but i have no clue what parts to use or how to best approach this. Im sure its all been perfected by you guys by now so what do you suggest? If you havent seen my build thread its a 200FF with rod slots cut and dump opened up.
05-23-2022, 01:46 PM #2
i guess any with a gauge attached to it
https://www.summitracing.com/parts/tnk-afpr1
or getting really creative with an adapter on the return hole
05-23-2022, 02:14 PM #3
Looks simple enough. Is there anything i have to plug or block on the oem set up?
05-23-2022, 03:01 PM #4
Noop you just extended the return route
Maybe the oil nipple below the vst and premix
TCW 3 hardly smokes when the engine is up to temperature
LakeFever thanked for this post
WTB 39# regulator
By R.I.P. in forum Misc. Parts and AccessoriesReplies: 2Last Post: 08-26-2018, 10:12 AM -
39 lb. regulator
By suprmag225 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 08-16-2018, 04:44 PM -
Holley blue pump and magna fuel regulator regulator
By bigbluechevy454 in forum Misc. Parts and AccessoriesReplies: 3Last Post: 10-26-2017, 07:35 PM -
41 Regulator
By challenger 77 in forum General Boating DiscussionReplies: 5Last Post: 09-30-2015, 08:00 PM -
Mercury Tech: V6 40 Amp dual regulator setup - can I run with one regulator?
By RoyE in forum Technical DiscussionReplies: 16Last Post: 08-18-2015, 08:49 AM
