Results 1 to 5 of 5
    May 2001
    Maine
    Making holes in Carpeted Bunks
    What is the best way to make a hole through carpet for a 1/4" x 20 bolt to pass to avoid a snag and wrecking it? I drilled the 3/4" PT plywood that I plan to cover with carpet already using a bit 1 size larger in diameter than the 1/4". All that I can think of is to use a pointed punch and make a starter hole in the carpet over the hole in the wood and just drive/ press the bolt through after the carpet is stapled down.
    Nov 2021
    N. Idaho
    Best to install carriage bolts before carpet. If you have to make a hole a sharp blade, punch, or something heated hot enough to burn through.
    May 2001
    Maine
    I like the carriage bolt as its a clean installation but not sure how it would work on 3/4" PT plywood, if I would have enough material after a slight countersink of the head. I am replacing a 7.5' x 1' trailer side platform. I took a small piece of K&S tubing and heated it with a lighter and it melted a perfect hole... still on the fence as to which way to go.
    Nov 2021
    N. Idaho
    I imagine you could do a clean installation with button head or counter sunk bolts also.
    Sep 2017
    ontario
    I think your on the right track- 3/4 ply - small hole poked - chalk marked - bump bolt in and snug / tighten til flush - meaning bite it a bit - not real proud but sunk . It's a carriage bolt - galvanized hardware . You hopefully didn't drill too large for the head to bite
  1. Trailer bunks
    By Troy VK in forum Tow Vehicles and Trailers
    Last Post: 04-12-2014, 05:34 AM
  2. Replies: 11
    Last Post: 12-31-2013, 08:12 PM
  3. Trailer Bunks
    By vnemous in forum Tow Vehicles and Trailers
    Last Post: 02-12-2009, 05:38 PM
  4. Difference in 2.4 head gaskets? (big holes vs small holes)
    By WATERWINGS in forum Technical Discussion
    Last Post: 10-18-2006, 08:59 AM
  5. rollers or bunks
    By PHISH in forum General Boating Discussion
    Last Post: 05-15-2006, 09:41 PM
