Results 1 to 2 of 2
05-17-2022, 10:55 AM #1New Member
- Oct 2013
- mississippi
23ft SANGER ALLEY CAT 245 DRAGS & 2001 200hp EFI MERCURY OUTBOARDS
THIS IS A SANGER ALLEY CAT 23ft OFFSHORE TUNNEL HULL. I FINALLY DECIDED TO GET RID OF IT BECAUSE I HAVE A NEW CATBOAT. WAS IN THE PROCESS OF RE DOING THE FLOOR, TRANSOM IS GOOD. HAS BOBS HYDRAULIC JACK N PLATES. LATHAN STAINLESS STEEL RACING HYDRAULIC STEERING. 245 MERCURY DRAG MID SECTIONS. ONE RIGHT HAND CLE LOWER UNIT. 245hp. ONE POWER HEAD WITH ONE BAD PISTON. CAN BE REPAIRED. OTHER POWERHEAD IS MISSING. ALSO COMES WITH A PAIR OF 200hp 2001 EFI MERCURY OUTBOARDS. RIGHT AND LEFT HAND. POWERHEADS ARE GOOD. INJECTORS WILL NEED TO BE CLEANED , FUEL PUMPS WILL NEED REPLACING. OTHER THAN THAT, THEY ARE GOOD POWERHEADS. THIS WAS THE PLAN TO GET AWAY FROM THE DRAG MOTORS AND GET TO SOMETHING THAT WAS MORE RELIABLE. COMES WITH TRAILER. TRAILER HAS SOME RUST ON IT, BUT HAS GOOD TIRES AND WILL PULL. EVERYTHING COMES WITH BILL OF SALE FROM MY BUSINESS AND LAST REGISTRATION. YOU WILL GET BOTH OUTBOARD MOTORS. 2001 , THE BOAT & TRAILER AND EVERYTHING THAT IS ON IT FOR $7500. NO NEGOTIATING . THE TWO POWERHEADS ARE WORTH THIS MUCH. READY TO SEE IT OUT OF MY WAY. WILL NOT SEPARATE, THIS IS THE ONLY WAY IT WILL BE SOLD . PICTURES OF THE BOAT ON SIDE OF THE HOUSE WERE TAKING YESTERDAY. THAT IS CURRENT CONDITION OF THE BOAT. IT WILL STILL WASH UP AND GEL COAT WILL STILL SHINE. WE ARE LOCATED IN GAUTIER, MS. YOU CAN TEXT WITH QUESTIONS TO : TWO TWO EIGHT- TWO ONE EIGHT -THREE ZERO EIGHT ZERO
sicknick12 liked this post
06-26-2022, 01:42 PM #2Member
- Jul 2003
- Lake havasu
- 76
The entire boat needs to be redone w rear bullhead at transom, that being said I would be interested in hull and trailer. Your way high in my opinion only w tje condition this boat is in. That being said if ur interested in selling hull and trailer only let me know? Thanks
23ft SANGER ALLEY CAT TUNNEL HULL PICKLE FORK CATAMARAN 245hp DRAG MERCURY'S $7,995.0
By walkinthin in forum Hulls larger than 20'Replies: 1Last Post: 10-07-2020, 01:33 AM -
Sanger Alley Cat
By jonnyd in forum Technical DiscussionReplies: 10Last Post: 12-18-2001, 11:56 AM
