Results 1 to 2 of 2
    Mar 2021
    Mb
    1999 150 mercury efi timing
    I’m going to check timing on my motor. I want to run 87 octane fuel. From what I understand I should set it to 19 degrees max. Does the efi have the timing module that people talk about unhooking so it doesn’t retard timing after 5600? Thanks
    Nov 2021
    N. Idaho
    You should unhook the white/black stripe from module to your switchboxes before timing. Factory spec 20° at cranking speed.
    Make sure you don't have one of these or it changes the ball game.Click image for larger version.
  1. 1999 Warhawk , 1999 Mercury 300 X
    By samwalls88 in forum Hulls up to 20'
    Last Post: 05-18-2022, 03:09 PM
  2. Timing 1999 Efi 150
    By Apex2007 in forum Technical Discussion
    Last Post: 07-25-2021, 03:24 PM
  3. 1999 225 3.0l Mercury
    By Hunterb1 in forum Outboard Engines
    Last Post: 11-06-2020, 02:46 AM
  4. 1999 merc 200 efi timing pointer (confused)
    By firedaddysc in forum Technical Discussion
    Last Post: 02-13-2014, 06:19 PM
