Results 1 to 11 of 11
Thread: timeing 2.5 200 carb
05-14-2022, 05:59 PM #1
Member
- Nov 2013
- palatka fl
- 94
guys what would be safe max timeing and pick up for my motor no black box 1993 2.5 carbs 200 hp bored 15 over fishing motor stock carbs bobs x-aust tuner thanks
05-14-2022, 09:28 PM #2
23 is usually considered safe on premium gas. I think it’s 19 on 87 octane. Someone else will confirm
Have you ditched the the oil pump and started premixing yet? 50:1 if you’re not over 6,000 rpm.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
TEXAS20225 liked this post
05-14-2022, 09:34 PM #31990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
05-14-2022, 09:34 PM #4
Depends on compression. 25* at 145-150psi is pushing it on 93 octane. Stock 115-120psi and 19* you should be fine on 87 all day. In between gotta pick the right spot.
'95 STV "The Blue Goose"
rgsauger liked this post
05-15-2022, 12:57 AM #5
Member
- Nov 2013
- palatka fl
- 94
thanks guys compression test next
05-15-2022, 11:39 AM #6
5000 RPM
- Aug 2019
- Palmharbor
- 456
- 20
- 19
- 54
- 121
If you use opti max as premix it has octane boost in it I run it 40:1 with 87 and 25 deg to 7k 140 psi Comp with 115 deg TStats up 2 on main jets/ NGK BUHW plugs
05-15-2022, 08:40 PM #7
Member
- Nov 2013
- palatka fl
- 94
05-15-2022, 10:05 PM #8
Ummmmmmm...Personally...I'd start at 23 degrees and read your plugs to see what's up before going to 25 degrees. You just spent a bunch of money on your motor and your compression is far from stock. It's your motor and your business but the last thing you want to do is melt a new motor when you're running 15 miles at 5K (or more) RPM from one end of the lake to the other. The difference between 23 and 25 on a fishing motor is negligible on performance
.066 mains??? that sounds SMALL to me. I would have expected .080-.084 or so. What carbs do you have?
Post your serial number and we can drill down on what Merc calls for it. You want to make CERTAIN that you have PLENTY of fuel for this beast. Best to start big and walk down as your plugs tell the story.
Have you broken it in yet? Good to go closer to 32:1 or so on oil for the first 5 hours. Then 40:1 for the next 5 hours.Last edited by rgsauger; 05-15-2022 at 10:16 PM.
05-16-2022, 06:55 PM #9
66 is stock for WHM series 2.5 200 carbs
05-17-2022, 01:26 AM #10
Member
- Nov 2013
- palatka fl
- 94
2.5 timeing
wmh-33 carbs will be useing shell 93 with nitrox most of time motor is broke in now was useing 32-1 merc syn will go to 40-1 as advised also to add this to post i am running twinns 2.5 s on a 24 ft off shore my other block is in machine shop it will be the same thanks again and i appreciate all help and advice
05-20-2022, 04:34 PM #11
I run 25* on the highest cyl (check all 6) then the rest is 25 or below 24 ,23
93 octane, 150lbs comp. 1000+ lbs boat , but I check my junk alot , 23 is safe but if u set #1 to 23. I'll bout guarantee u will have atleast 1 cyl at 25* possibly 26
FORBESAUTO liked this post
port timeing
By jay1 in forum Technical DiscussionReplies: 5Last Post: 03-09-2009, 07:53 AM -
Mercury Tech: Timeing question
By jimmyz32 in forum Technical DiscussionReplies: 1Last Post: 09-04-2008, 01:17 PM -
Timeing/flywheel.
By MTN BOATER in forum Technical DiscussionReplies: 17Last Post: 04-23-2007, 07:33 AM -
Intakes and timeing on V4 OMC
By Monkstr6 in forum Technical DiscussionReplies: 3Last Post: 09-05-2006, 04:03 AM -
timeing question
By JACK R. in forum Technical DiscussionReplies: 1Last Post: 03-14-2004, 10:27 PM
