Results 16 to 30 of 32
Thread: 140hp crossflow
05-18-2022, 08:01 PM #165000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
So the 135hp I have a pic of above is a1976. How many parts are interchangeable with my 1980 140hp? Are the heads higher compression heads than my 140? Carbs? Lower unit? Bubble back? I think the block would be the same 99ci. I think I can get it cheep, just wondering if it’s worth it for the parts since I just picked up the 115hp for odds and ends parts…
05-18-2022, 08:22 PM #17
Iirc the 76 135 had the highest cr heads but they dont have the brackets for coil mounting. The numbers you posted are the good low comp ones. The later versions on the 110’s were really low comp. iirc the 79 140 was the last year with the high comp heads. I was building a 140 a couple years back and there was some great threads going with good info. Theres also the unicorn tuner for these a one year only deal.
05-18-2022, 08:23 PM #18Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
135 had 2 versions of heads, pretty sure both tighter than a 140.
They ran fine in OZ as we still had leaded 98 when they came out and for the next 10 years
05-18-2022, 08:29 PM #195000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-18-2022, 08:41 PM #20
I dont know a ton about the 135’s but aside from the 90 the blocks and porting are the same
from what i can recall. The bubble back and stuffers are what set the 135 and 140 apart from the 115. Some had the big carbs some didnt but from what i read there isnt really a lot of gains with the bug carbs but just what i read keep in mind. I ended up buying three of these motors myself; a 79 140 and a pair of late model 90’s. Never got around to hanging one on my vandal i got the 75 on there working pretty good so i left it and ran it.Hydrostream dreamin
05-18-2022, 08:46 PM #215000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-18-2022, 09:07 PM #22
Thats exactly how i see it. Better to be lookin at it then lookin for it lol. I have a four v6 mercs now too for the same reason
05-19-2022, 09:42 AM #235000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
That’s a good block esp if it’s a freshwater engine little mods like cleaning up the casting inside intakes
Radius all of its corners and in the exhaust matchup inserts and fix the plunge cut for the bulb dump back to block .if you can find some reeds from a junked 175 60deg Etec there big on flow will fit right in and make big power
LakeFever liked this post
05-19-2022, 10:41 AM #245000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Sounds good. Thanks.
05-20-2022, 09:08 AM #255000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
I have a 15 inch mid and lower with bobs cone and a cut trim for that engine
05-20-2022, 09:28 AM #265000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-20-2022, 07:04 PM #275000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
Yes it would it’s a land & sea kit or you can make a tiller motor out of it 14 ft skiff
05-20-2022, 08:28 PM #285000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-21-2022, 07:01 AM #295000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
What was a problem was they had a top L ring and hi rpm caused ring failure I think it’s was in 76-77 models just check when the heads are off those pistons should be swapped ore you could look thrue the transfer windo plate
05-21-2022, 07:12 AM #30Member
- Sep 2021
- New Richmond, Ohio
- 91
- 27
the pistons were lighter bad gas was the problem i rebuilt a lot of them back then use good gas drop timing back 2 degs use 93 pump gas should be ok
Re-building a 1980 Johnson V4 140hp crossflow
By spybot in forum Technical DiscussionReplies: 36Last Post: 03-19-2020, 09:11 AM -
omc v4 140hp crossflow piston difference from 1983 to 1984?? same rings though..
By syclone01 in forum Technical DiscussionReplies: 4Last Post: 10-08-2011, 02:01 PM -
OMC Tech: 140hp Johnson No Top End
By richcraft in forum Technical DiscussionReplies: 14Last Post: 05-24-2009, 11:17 AM
