Results 1 to 13 of 13
    Jul 2002
    florida
    1987 25hp lower unit nose cone...
    Hey all, I called bobs today to inquire about having a nose cone installed on my lower unit. He requested pictures and I sent them. The issue is there may not be room to tap into the impeller housing? He asked for pictures with the water pump housing removed. I just installed a new one and was hesitant to break the new seal but I'm going to go ahead and do it. Has anyone on here have any experience with adding a nose cone on one of these small motors? Any tips or advice?
    Michael
    Co-Founder of Airide Powerboats
    12 ft. Custom Vee 50hp mod. Johnson
    23 ft. Chris-Craft Scorpion: 350 Chevy
    Mod. 25hp Johnson
    Dec 2001
    I would just take 2 plates and block that area...... then put 2 holes on the bottom of said plates just so not to suck air.......just H2O.....Or if ya look at the gear case..... pull off the pump housing and notice the front cavity goes down to the small draine hole on the side..... use that cavity as a water source......more foward to get a better flow that the stock pickups.......Drill the cavity deeper to get lower......put 2 holes on ether side.
    Jul 2002
    florida
    Thanks for the feed back, ill look into that.
    Michael
    Mod. 25hp Johnson
    Aug 2009
    mpls,mn
    Dont think bobs even has aor makes a cone for anything that small like that 35hp omc you get there.
    I make my own as in casting an alumn one from a lost foam mold.Just did this one for a omc nitro / 40/50 hp lower.
    Attached Thumbnails Attached Thumbnails lathe lower unit 004.jpg   lathe lower unit 005.jpg
  5. Likes Dave S liked this post
    Jul 2002
    florida
    Nice man! Yes bobs makes them for the small motors but only for certain ones. Like mine, I can't seal off the original hole because I have to access it to remove my shifting linkage to remove my water pump housing. Can you give me more information on how you make yours?
    Michael
    Mod. 25hp Johnson
    Dec 2001
    Yep if ya can't buy it make it.....
    Jul 2002
    florida
    I'm wondering if I could add a cone and run the water hose from the top of the cone to a custom plate I could mount over the existing spot where the water pick up goes. Put two solid plates on with one having threads for the new hose that would come from the nose cone. Idk. Just wondering how I can do this. I want to keep the stock lower because I use reverse.
    Michael
    Mod. 25hp Johnson
  9. #8
    Jul 2002
    florida
    I've also been asking around for information on how to install a nitrous set up on this motor. If someone could point me in the right direction I'd appreciate it. I know the builders that made my hull ran nitrous on their 25's and 40's but there is no longer any way to get in touch with them.
    Michael
    Mod. 25hp Johnson
  10. #9
    Aug 2009
    mpls,mn
    I dont have a 35 case laying around right now but will check it out on line and see if something can be done.
  11. #10
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by boataddict26 View Post
    Don't bother with all that. Make block-off plates on the side where the water pickups are now, and then drill a hole for the water transfer right under the water pump area where everyone always does. You can make a bob's cone work but you have to cut it in 2 directions and weld it back together...I wonder how I know lol
  12. #11
    Jul 2002
    florida
    Thank you im appreciative for any and all advice and information.
    Michael
    Mod. 25hp Johnson
  13. #12
    Jul 2002
    florida
    Great idea, I will look into that for sure. Do you have any pictures?
    Michael
    Mod. 25hp Johnson
  14. #13
    Jul 2002
    florida
    Thank you
    Michael
    Mod. 25hp Johnson
  1. Lower Unit with a different nose cone.
    By Hydrodreams in forum Technical Discussion
    Last Post: 12-08-2019, 04:09 AM
  2. Nose cone on lower unit, help.
    By 500dollar744ti in forum Technical Discussion
    Last Post: 10-17-2013, 04:20 PM
  3. Lower unit repair (nose Cone)
    By boater777777 in forum Technical Discussion
    Last Post: 05-17-2010, 01:38 PM
