Results 16 to 30 of 35
Thread: Building 225 promax SS
05-12-2022, 09:57 PM #16
25two.stroke, TEXAS20225 liked this post
05-13-2022, 02:25 AM #17
I think it would be easier to fix your low temp issues then try to run a 2 piece plate. Can you post a picture of how your dumping water from your PM.
US1 has some proven steps on how to run 1 piece plates on steel sleeve blocks
05-13-2022, 11:07 AM #18
05-13-2022, 06:21 PM #195000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
If the Devertes are in correct location. It will make heat.
05-14-2022, 08:19 AM #20Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
A 1 piece plate works way, way better in environments that have limited swings in water temps. In my experience with both set-ups, it was tough to make the 1 piece work properly in my waters up here. It certainly can be done, but can be a PITA. The 1 piece as was said above is designed for high volume water throughput in mostly race applications, adding another twist to the equation.
There is a lot of info on S+F on this, so be sure to dig back into the archives for added info.
05-14-2022, 05:01 PM #21
stock 2 piece put it all together bone stock (except solid mounts) and go.. one piece, are tha dump holes to big or to little?.. are tha pee hoses restricted to much or not enough?.. does tha block have tha right holes "relocated" in tha bottom.. water pressure to high or to low and etc. and etc........... some like havin' to fool with all that ta get it right and some don't... up to you, gl.......... jmo
05-14-2022, 10:55 PM #22
How do you plan to use your PM.
If you go to a 2 piece, your going to have to match the PM exhaust to a PM 2 piece plate or a mid 80's 2L 2 piece plate.
Running stock exhaust plates with a popit, thermostats and the correct water dumps will help you eliminate a cold seize.
05-17-2022, 10:05 AM #23Member
- Feb 2019
- Midwest
- 82
As of right now my 225 SS is using just a 280 1 piece plate. Not sure how big the drain holes are but I will be removing the powerhead today/tomorrow. I run the fender washers in the head as US1 recommends. I plan on trying to put the 2 piece plate from a 225 promax sport on but if that doesn't work I will be threading the drain holes in the 1 piece plate and putting brass plugs with 19/64 drain holes. When the water temp is 80 degrees and air temp is 80 to 90 degrees my motor has no issue getting to the 140-150 degree mark but if I was to take it out in the fall when water temp is low 60s, the motor wouldn't build much past 110 degrees.
Wilson-Racing liked this post
05-17-2022, 10:07 AM #24Member
- Feb 2019
- Midwest
- 82
When you say to drill the solid mounts are you referring to the stock ones or getting a set of aluminum ones from Bob's? My only concern with drilling them is the stock heavy duty bolts from the 1 piece don't seem long enough to reach the solid mounts in the 2 piece plate.
05-17-2022, 11:32 PM #25
yes.. drill tha solid mounts to accept tha larger dia bolts due to tha size of tha holes in tha tiller arm.. they will need longer than tha ones used with tha one piece.. don't agree with some that use tha stock 7/16 dia 'cause it results in slop thru tha 1/2 holes in tiller... jmo.
this site will give ya an idea of cost....
Socket cap, Stainless steel 18-8, 1/2"-13 - Bolt DepotLast edited by tlwjkw; 05-17-2022 at 11:40 PM.
05-17-2022, 11:38 PM #26Member
- Feb 2019
- Midwest
- 82
05-17-2022, 11:57 PM #27
you can find tha right length.. jus take some diggin'.. sleeve might work ok... don't remember if tha big tiller will take a "hex" head instead of tha allen cap head??? may not be able ta get a socket ta seat on it?
05-24-2022, 06:39 AM #28
I just picked up a 2000 Pro Max that came factory on a 20" offshore mid. It has a 280 style one piece plate and runs thermostats. Cant you just run thermostats on your one piece plate?
05-24-2022, 06:55 AM #29Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
05-24-2022, 07:20 AM #30
Did you read my messages on your other thread? Keep your one pc plate, modify it with some angle aluminum and epoxy/marine tex and run a poppet and thermostats
https://www.screamandfly.com/showthr...er-plate/page41973 Viper - sold
1978 Viking - sold
1995 XB02
150 ProMax....Finding one or building one
By 1FASTLASER in forum Technical DiscussionReplies: 51Last Post: 02-05-2014, 11:47 AM -
Performance building a 300 ProMax???
By jrumon in forum Technical DiscussionReplies: 12Last Post: 12-01-2004, 12:23 PM -
re building 260
By big poppa pump in forum Technical DiscussionReplies: 2Last Post: 10-01-2004, 07:56 AM -
Thanks GPI for building my V-21
By j.iverson in forum General Boating DiscussionReplies: 19Last Post: 08-23-2004, 07:10 PM -
building new shop looking for a steel building
By eautosales in forum The Scream And Fly LoungeReplies: 12Last Post: 12-15-2002, 09:32 PM
