Results 106 to 120 of 235
06-02-2023, 02:47 PM #106
West system epoxy and silica filler
06-04-2023, 01:07 PM #107
progress today on the port sponson. First piece of ply fitted and installed. Forward piece was fitted and cut to rough size. Backing block for the joint between the two pieces also cut for exact fit between the stringers, laminated and ready to install. FINALLY putting pieces back ON the boat instead of taking it apart...
89LASER liked this post
06-21-2023, 03:40 AM #1086000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
06-21-2023, 03:52 AM #1096000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
In today's world if race boats were built out of wood, the skins would be ka-chinked on with air driven staples..........much quicker! Seebold and other builders went to the trouble of using aluminum screws to save weight. Trouble was that no race boat was expected to last over 4-5 years. You could have a perfectly maintained hull and the paint or epoxy finish would end up bubbling up at the screw locations with powdered corrosion.
06-21-2023, 09:57 AM #110
07-02-2023, 07:47 PM #111
little bit of progress. Starboard sponson side glued in place. soon to start on the sponson bottom running surfaces...
07-07-2023, 02:10 PM #112
both port and starboard sponson side panels installed and planned to final size. Started laying out the port sponson bottom running surface, 9 MM okumi play. Test fit to insure proper location and laying out and pre drilling fasteners locations. Reinforced on of the ribs to be wider and placing the running surface joint directly over that position. (thank you Mark). Waiting on ring shank nails. Maybe get this installed late this week...
89LASER, scott reierson liked this post
07-14-2023, 12:10 PM #113
progress. Skins on the Port side sponson. filling screw and nail holes in the nice cool florida weather.... NOT !!! ITs friggin HOTT !!!!!!!!!
scott reierson, 89LASER liked this post
07-18-2023, 08:43 AM #1146000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
07-18-2023, 10:04 PM #1156000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 499
- 198
That closeup of that chine/bottom joint looks awesome! Cool! Very nice work.
07-19-2023, 05:39 AM #116
08-01-2023, 01:41 PM #117
botom being sanded and the first of three coats of epoxy being applied. Such fun in the 96-degree Florida heat... Roger H where are you when i need you ??????
08-03-2023, 06:08 AM #118
And what else to do at 5 am other than mix epoxy, chill it in an ice tray and apply a little bit to beat the Florida heat ?
Hydrovair liked this post
08-04-2023, 05:48 AM #119Member
- Oct 2013
- Palm Bay Florida
- 68
- 21
- 38
- 26
Looking good Tom, Why the difference in the chine on the pads?
08-04-2023, 01:24 PM #120
That’s the way it was originally built.
18’ Baker Tunnel Restoration
By Pilotryan in forum Boat Build-Ups and RestorationsReplies: 8Last Post: 01-11-2022, 01:08 PM -
Allison XST18 Restoration Complete
By freeebird in forum General Boating DiscussionReplies: 7Last Post: 07-14-2021, 08:03 PM -
Phantom 25 - 30 years ol getting complete restoration
By Toffen in forum General Boating DiscussionReplies: 16Last Post: 05-23-2015, 11:56 AM -
Engine height on DelCraft Wooden Tunnel Hull:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 7Last Post: 06-25-2010, 12:11 AM -
14' DelCraft Tunnel & 850XS W/SSM:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 4Last Post: 10-22-2007, 09:23 AM
