Results 1 to 9 of 9
    Jun 2009
    CA
    300X cooling issue
    I have a twin 300x setup. (fresh water only boat)
    Starboard motor warms up and idles around 110 /120, runs 120/130 in no wake zone, and is at 140 /160 when running.
    Port motor has developed an issue.
    warms up at 120/140. runs 140 /160 in no wake zone. and 160 / 190 when running at speed.
    both motors have the same water pressure at idle and when running hard.
    And both are peeing strong out the side.
    impellers were recently replaced.
    I thought it may just be a problem with the thermostats.
    Replace both with new ones and did not change the problem.
    Anyone have any insight on what may be wrong???
    Sep 2007
    bay city mi.
    Analog guages?
    Jun 2009
    CA
    Yes they are analog gages.
    Sep 2007
    bay city mi.
    Mine read about the same spread confirmed with temperature gun the motors were the same. Then I just always knew one showed hotter then the other. Then I went with smart craft and showed they were the same on there. They have two sending units for the motor one digital one analog. The analog ones do not screw into the head but have a hold down clip.Try swapping them in the motor and or the wires between the gauges. Might just be that.
    Jun 2009
    CA
    Thanks kct11,
    I will try swapping the gages next time I take the boat out.
    Never would of thought a simple analog temp gage would go bad.
    Sep 2007
    bay city mi.
    It could be one or the other. So if you swap the guages and it's the same, then swap the sending units.
  7. Thanks F29DCB thanked for this post
    Jun 2009
    CA
Name:	Screen Shot 2022-04-28 at 1.34.09 PM.png
    Is this the analog sensor ?
    iinul812751062749
  9. #8
    Sep 2007
    bay city mi.
    The one with brown black wires above the digital one(you posted the digital above). That's if you have a later 300x
  10. #9
    Jun 2009
    CA
    Thanks for the clarification kct11
  1. Mercury Tech: yet another cooling issue
    By skeeter91 in forum Technical Discussion
    Last Post: 11-13-2018, 10:53 PM
  2. 2002 Mercury 150 Cooling Issue
    By kapslock16 in forum Technical Discussion
    Last Post: 07-06-2017, 07:31 PM
  3. Omc v8 cooling issue
    By wfowahoo in forum Technical Discussion
    Last Post: 07-02-2014, 05:29 PM
  4. Mercury Tech: 200hp Cooling issue
    By nacimientobound in forum Technical Discussion
    Last Post: 10-01-2012, 07:41 PM
  5. 1972 Evinrude 40HP Norseman Cooling issue
    By ktmrider37 in forum Technical Discussion
    Last Post: 07-25-2006, 08:31 PM
