Results 1 to 7 of 7
    Dec 2004
    Ocean Springs, MS
    Pro Max 225 propeller
    I am looking for a few props to try on my Glastron Carlson CVX-16 that I'm fixing to hang a Mercury 2.5 Pro Max 225 on. I want to prop it for midrange acceleration versus top end. The boat weighs under 800 lbs. Due to the engine weight 375-400 lbs I believe a 4 (or 5) blade would be better to add some stern lift while taking off. Since the boat is so light I suspect that the prop will not require a large diameter. Any suggestions here would be most appreciated.
    Lake Coochiching, Ontario
    A used 26 Trophy would be a good starting point (I almost always say this).
    Does the boat have a pad?
  3. Likes whipper liked this post
    Minneapolis MN
    +1 for a Trophy. They're plentiful and should be able to be found for less than 500.
    225PM is a great engine, I love mine. Bone stock pushes my Hydrostream to the mid 90's.
    Dec 2004
    Ocean Springs, MS
    Yes, it has a 6" wide pad. The hull has no trouble generating bow lift.
    Dec 2004
    Ocean Springs, MS
    I think the Trophy recommendation is good advise. I forgot to mention that this motor has the Sportmaster gearcase. This hull doesn't really need it and would run fine with a Torquemaster but the engine builder says it won't hurt anything to run it on my hull.
    Prince George B.C. Canada
    Setup is the key on a hull like that and what you want to get out of her. Being a straight vee and enough power to make her jump out of the water like a kangaroo that transom area and setup would be my focus first. The difference from a 23 pitch to a 25 or 26 with a promax will be like wild quick to just wild! haha But ya cant go wrong with a trophy to find were ya want to be. :]
    Jul 2021
    Pompano Beach
    A bravo XS would also be a good choice.
  1. Mercury Tech: Propeller
    By tabme in forum Technical Discussion
    Last Post: 01-20-2019, 09:07 AM
  2. Propeller Case / Propeller Box - Shipping and Storage
    By Mr. Demeanor in forum Propellers
    Last Post: 04-30-2014, 10:15 AM
  3. A-Z Propeller Co.
    By PROGRESSIVEAUTO in forum Props, Setup, and Rigging
    Last Post: 05-16-2006, 06:51 AM
