Results 16 to 22 of 22
Thread: oil injection
05-04-2022, 04:18 AM #16Member
- Apr 2022
- melbourne australia
- 33
- 40
Hi guys just need to give a big thank you to everyone for there input as i have successfully removed the oil injection system and mixed 50to1 and she runs idles better and runs smoother starts easier and less smoke as im only running in tank at moment as i want to do one thing at time and test the results ?next il remove the black box (my motor only has one box) so im still strugling & trying to read exact info regarding the wiring when i remove it, also does anyone have a link or part no or any info on where i can get a workshop manual for my merc 200 carbed 1987 a PDF would be ideal for me but i cannot find anything for my exact engine. thank you
05-05-2022, 06:53 AM #17Member
- Apr 2022
- 33
- 40
05-05-2022, 11:48 AM #181980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
hobbymad thanked for this post
05-13-2022, 12:15 PM #19
The "black boxes" modify timing by moving the bias voltage one way or t-other. Just remove them. You will find the bias wire goes to a screw with a jumper to the other swichbox. Leave that jumper in place. It synchronizes the switchbox timing.
To fish or not to fish? What a STUPID question.
05-13-2022, 08:37 PM #20Member
- Apr 2022
- 33
- 40
Hi j-Martin thanks for info but when you say boxes I only have one box on port side it has 3 wires going to switch boxes and 2 wires from motion sensor going into it plus ground wire so everyone talks about removing the box’s but I only have one on my engine? Is this unusual am I the only one with a merc that only has one box or is it different because mine is an Australia model? I’m bit confused
05-14-2022, 09:33 PM #21
Ditch that box
05-16-2022, 08:29 AM #22
The "black boxes", ie the idle stabilizer and spark advance modules are small, usually sit on top of the engine, and have 3 wires, a ground, and 2 that go to the switch boxes, one to a stator wire, and one to a bias terminal. Normal count is 0 to 2. In other words they may or may not be installed.
The box you describe must be the oil alert module. It should have a ground wire, 1 wire to the oil tank cap sensor, 2 wires to the motion sensor, and 3 across the top to 12V, the alarm circuit, and a switch box coil terminal. Remove it.To fish or not to fish? What a STUPID question.
crankcase injection- point in time of injection to fire injector?
By mrcrsr in forum Technical DiscussionReplies: 0Last Post: 08-08-2012, 06:38 AM -
point in time of fuel injection, has anyone played w/ different injection points?
By mrcrsr in forum Technical DiscussionReplies: 7Last Post: 01-28-2011, 08:21 AM -
How can you tell Laser injection from other 2.4 injection
By jowens in forum Technical DiscussionReplies: 10Last Post: 10-10-2009, 10:29 AM -
Oil injection on a 3.0L 225
By zachp13 in forum Technical DiscussionReplies: 3Last Post: 05-15-2008, 10:02 AM -
Direct Injection + Conventional Injection
By David in forum Technical DiscussionReplies: 3Last Post: 02-28-2006, 06:14 PM
