Results 1 to 15 of 22
Thread: oil injection
04-22-2022, 08:52 AM #1Member
- Apr 2022
- melbourne australia
- 33
- 40
oil injection
Hello everyone i will be deleting the oil injection on my 200 merc 1987mdl and need to know from people who have done this
1-what preemix ratio will be best, 2- will any carby jetting or adjustments be required, 3-will i need to change the ignition timing? the comps on my powerhead are all130psi , also i would like to know if there are any modifications i can do to make it sound and run quicker? any help would be great thank you
04-22-2022, 11:10 AM #2
50:1
No carb jetting changes for oil injection.
No timing changes, just get rid of the stabilizer module and set the timing per the manual.
Lots of things make those motors quicker...it depends on how much time and money you wanna spend.
04-22-2022, 11:41 AM #3
If your running over 6500 to 7k for extended time 40:1, much over 7500 best go 32:1.
hobbymad thanked for this post
04-22-2022, 12:54 PM #4
Yep, under 6K, 50:1. Over 6K, 40:1
Ditch your black boxes, too1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
04-24-2022, 03:09 AM #5Member
- Apr 2022
- 33
- 40
Thanks for your help Dave
04-24-2022, 03:10 AM #6Member
- Apr 2022
- 33
- 40
Appreciate your help thanks
04-24-2022, 05:30 AM #7Member
- Apr 2022
- 33
- 40
04-24-2022, 05:38 AM #8Member
- Apr 2022
- 33
- 40
04-24-2022, 12:02 PM #9Junior Member
- Nov 2021
- Williams Bay, WI
- 11
- 13
- 9
- 7
- 10
hobbymad
I just recently removed oil injection, alarm module, and idle stabilizer on my 1984 150 black max. I researched many Scream & Fly posts, all combined in my description. Follow the link and see step 15
https://www.screamandfly.com/showthr...ection-removal
04-24-2022, 01:25 PM #10
That link will give you all the info you need.
RockTeam Junk
hobbymad thanked for this post25two.stroke liked this post
04-25-2022, 08:17 AM #11
By the way, welcome to Scream and Fly!
04-25-2022, 07:33 PM #12Member
- Apr 2022
- 33
- 40
Thank you and there’s one thing bothering me about removing the black box on port side as there is 5 or 6 wires coming out of it so what do you do with those wires ? I know everyone says get rid of the black box but do you remove the wires from cdi box and throw the black box out with all wires or do some wires need be joined somewhere?? My engine is 1997 200 black max, so far I’ve been given great information that’s helping me out but I’m very cautious about removing wiring as I don’t want cause anything to fry?
04-25-2022, 07:37 PM #13
not a whole lot you can do to add power without tearin it down and doin alot of exhaust port work and rebuild. ask me how i know,lol
04-26-2022, 02:38 PM #14
Search "black boxes" and you'll find what to do. The only main thing to keep in mind is that there will need to be a "bias" wire connecting the two switchboxes on the Starboard side. It might already be there. If not, it has to have it when you ditch the boxes. I think it's white w/ black by memory.
04-26-2022, 10:07 PM #15Member
- Apr 2022
- 33
- 40
rgsauger liked this post
crankcase injection- point in time of injection to fire injector?
By mrcrsr in forum Technical DiscussionReplies: 0Last Post: 08-08-2012, 06:38 AM -
point in time of fuel injection, has anyone played w/ different injection points?
By mrcrsr in forum Technical DiscussionReplies: 7Last Post: 01-28-2011, 08:21 AM -
How can you tell Laser injection from other 2.4 injection
By jowens in forum Technical DiscussionReplies: 10Last Post: 10-10-2009, 10:29 AM -
Oil injection on a 3.0L 225
By zachp13 in forum Technical DiscussionReplies: 3Last Post: 05-15-2008, 10:02 AM -
Direct Injection + Conventional Injection
By David in forum Technical DiscussionReplies: 3Last Post: 02-28-2006, 06:14 PM
