Results 1 to 2 of 2
    Oct 2005
    Houston, Tx.
    Evinrude 75 completely rebuilt
    1976 Evinrude 75 shortshaft EP/SE outboard, totally rebuilt (powerhead, swivel bracket, gearcase), many new parts. Comes with OMC Racing break-in instructions (30 min. at variable speed). New fuel pump, new crank, new rings, 2 new pistons (rebored), new crank seals and rod bearings, new gears and gearcase seals, new impeller kit. Motor was started and run briefly on a stand. Can be crated by a friendly dealer for $150, buyer arranges shipping if shipping is desired. $3300 with wiring harness and OMC key switch.
    Attached Thumbnails Attached Thumbnails IMG_2502.jpg   IMG_2500.jpg   IMG_3617.jpg   P1010075.jpg   P1010072.jpg
    Oct 2005
    Houston, Tx.
    Sold
    Quote Originally Posted by smokin'joe View Post
    I sold the motor for $3750 with a new Booe 12x22.5 prop (the prop was designed for SST60 Class). I did not rework the prop, I only trimmed the diameter. The motor will be mounted on a 12' Laser boat. The Johnson 60 shortshaft, an SD motor, was sold last spring. So the only racing motors left here are our 1979 Stinger (in service on the May Fly III) and a rebuilt and refinished 1975 Evinrude 75, which is on display in our garage. That's it for the 1970s era OMC racing motors.
  3. Thanks doug7488 thanked for this post
    Likes doug7488 liked this post
  1. Evinrude 235 Rebuilt
    By mbeuro in forum Technical Discussion
    Last Post: 01-04-2022, 08:59 PM
  2. 1997 2.5 200 powerhead completely rebuilt
    By ShadowFlier in forum Outboard Engines
    Last Post: 06-05-2020, 10:17 PM
  3. 1978 Evinrude 140 Rebuilt
    By Xlrator in forum Outboard Engines
    Last Post: 12-27-2016, 07:13 AM
