Results 16 to 21 of 21
Thread: when to rering a nic motor?
04-20-2022, 03:41 PM #16Junior Member
- Sep 2012
- east tennessee
Okay, decided to pull the motor apart, better to be safe than sorry. So even with a good leakdown and compression this thing was about to fly apart. # 6 piston has damage from detonation, plus it look like the previous owner ran it a good while like this. Some how the nic looks good. Got my pistons today and pins should be here soon. All sleeves are aluminum. I feel fortunate that this motor did not destroy itself. Thanks to the good advice from this forum, you all saved me a motor. I will update this again in a few weeks.
CI STV, 25two.stroke liked this post
04-21-2022, 03:12 PM #17
On the block it looks like theres indents from a gasket and indents from an oring. Curious, was there oring heads on that motor or gasket heads?
It looks a little lean in my opinion. And...it may be an optical illusion, but it looks like there is a LOAD of piston to wall clearance on that cylinder? Hopefully thats just the pic though.
Beak Boater liked this post
05-05-2022, 01:15 PM #18Junior Member
- Sep 2012
- east tennessee
The motor had head gaskets, I am sure the heads have been milled, chances are it was also ran with oring heads too. I will run a set of stock head with orings, as this is just a lake motor. Spoke to the previous owner and showed him the pics of # 6, he did not know about the damage and I believe him, as he is a stand up guy and was very honest about the history of the boat and the engine, this stuff just happens when you buy something used and you do not know the full history. He did tell me that before the sold it to me that the engine would accelerate and then when they got back in the throttle it would lay down. They sent the injectors for cleaning and the ECU to Brucato. The ECU checked good, but after retesting it did the same thing. So they sent the ecu back to Brucato and it they replaced it as it showed an intermittent problem. I bet it was run lean during the box trouble, plus they ran their oli at a higher ratio than I think is good.
I will measure bores and verify clearances. I am planning on a re nic on this block. Glad I have another boat as I bet it will take at least two months to get the block back from Custom Chrome. I will update this post when I know more. Thank you for the good advice
05-05-2022, 02:55 PM #19
stoker2001 liked this post
05-07-2022, 04:50 PM #205000 RPM
- Jun 2014
- United States
- 147
- 29
- 40
Inquiring minds have got to know!!!
05-08-2022, 03:06 PM #21Junior Member
- Sep 2012
- east tennessee
25two.stroke, stoker2001 liked this post
Rering or bore + OEM piston good?
By bigboy in forum Technical DiscussionReplies: 4Last Post: 03-06-2019, 04:20 PM -
rering a 260
By bay area in forum Technical DiscussionReplies: 1Last Post: 11-23-2010, 05:12 PM -
merc leakdown(rering)
By alwayssomethin in forum Technical DiscussionReplies: 2Last Post: 03-18-2009, 03:46 PM -
Maroon Scotch Brite on a ReRing
By Hottrucks in forum Technical DiscussionReplies: 11Last Post: 06-03-2007, 09:58 AM -
What to pay for a rering job
By jponfrank in forum General Boating DiscussionReplies: 14Last Post: 07-14-2003, 04:36 PM
