Results 1 to 8 of 8
Thread: Tritoon engine setup
03-15-2022, 01:40 PM #1New Member
- Oct 2021
- Mid Michigan
I have a 2016 Veranda 25ft tritoon with a 2016 Yamaha 250 sho outboard. Currently with a clean hull the boat will see 45-47 with a 17 pitch power tech 3 blade prop at 5800 rpm and about 48-49 with a 19 pitch saltwater series 2 prop spinning at 5500 rpm.
I plan on sending my ecu to nizpro marine to get it tuned to 332hp. My main question is if I can raise my engine on the transom to get more speed with the 19 pitch prop and the 332hp tune.
I would like to hit 55 mph, so on top of the tune can i raise the engine height or change the prop?
Thanks for the help
03-15-2022, 03:56 PM #2
I’ve not set up a tritoon yet but I sure will be one of these days. Can’t see the process differing much with regards to set up. Raise the motor as high as you can while watching water pressure and pitch up the prop until you slow down or can no longer live with the weaker hole shot a taller prop brings. I don’t know what props work best on those. Hope something here helps you a bit
VSlavov liked this post
03-16-2022, 12:46 AM #35000 RPM
- Jul 2021
- Pompano Beach
- 145
- 16
- 38
Nizpro raised the rev limiter with their tune, so chances are your 19" prop will work, you'll just be spinning it faster. Yes you can raise the motor, but you may run the risk of not being able to get on plane with people in it if the motor is too high.
03-16-2022, 05:14 AM #4New Member
- Oct 2021
- Mid Michigan
03-16-2022, 08:47 AM #55000 RPM
- Jul 2021
- Pompano Beach
- 145
- 16
- 38
No idea. I'd run your boat at 40 mph and look back there and see where the cavitation plate is before I'd do anything. One of my customers owns a large pontoon dealership in TN. He told me on the 250 SHOs if they removed the cowlings in summer time they'd gain 500 rpms WOT.......not sure if the cowlings are too restrictive or what. I never tried it on mine.
03-16-2022, 09:07 AM #6New Member
- Oct 2021
- Mid Michigan
03-16-2022, 05:44 PM #75000 RPM
- Jul 2021
- Pompano Beach
- 145
- 16
- 38
Yes, just on top of the water. I'd do the tune and run it with existing 19" prop and existing height and see what your numbers are and where the cavitation plate is.
VSlavov, Asstracker liked this post
04-02-2022, 12:55 PM #8Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7154
- 3 Post(s)
I wasn't sure what gains I would see with motor height increase but common sense told me drag is drag and set back will get me clean water along with the C.G. moved back. We installed a 17" Porta bracket and sportmaster on my 300R (replaced the 5.44 H.D. case) and I run the height up until the tach outruns the g.p.s.. It varies just how high I run it depending on the load but it gained 5.5 mph from my previous best. I run a 20 pitch Enertia Eco 16" dia. that FJ propeller (love rubbed) with a 1.75 gear and have seen a best of 60.1 mph. I have a friend with a 450 on his (same toon) and he has seen a best of 67. I think he could do better with set back on his and a little more attention to details.
We did fill in the bottom side of the deck so that it is as smooth as "reasonably possible" and built the transom support up on the center toon along with welding a 1/2 alum plate to the exterior of the center log.
Its funny, not too many people will pull up to me in my other boats and want to play but every toon out there wants to race LOL-
Playcraft Tritoon w/Verado 350 - looking for engine setup advice
By tdogcarter in forum Props, Setup, and RiggingReplies: 4Last Post: 09-08-2021, 09:21 PM -
Help with "performance tritoon" setup
By tronman in forum Props, Setup, and RiggingReplies: 13Last Post: 06-20-2016, 08:41 PM -
24' tritoon w/ 250xb setup?
By Csmyj in forum Props, Setup, and RiggingReplies: 19Last Post: 07-27-2015, 07:27 PM -
Best SBC Engine Setup
By swampfox44 in forum Jet Boats, V-Drives and Stern DrivesReplies: 1Last Post: 06-20-2009, 08:12 PM -
Twin engine setup
By slikcraft in forum Technical DiscussionReplies: 6Last Post: 07-19-2005, 11:57 AM
