Results 1 to 10 of 10
    Best prop for a 22' flats boat with 250 XS 4 stroke
    Nephew got a new 4s and it has a new 4 blade bravo 1 on it. (vent holes plugged) Mounted on a a 22' flats boat. Has a lot of slip and can't shed the air and cavitates until over 3k r's. Holeshot is terrible due to cavitation. Old opti 225 had no issues with a 4 blade power tec. Any props that would help? I have zero experience with the new merc 4 strokes....
    Florence, SC
    I had a Max5 on my Lake & Bay... worked beautifully!!
    David "Tango" Wilks
    Current boats: (Not All Running...LOL)
    18' VT-Rocket Bass Boat: 2.5L 280 Mercury
    21' Eliminator Daytona: Stripped and Possibly For Sale!
    24' Skater: Uncut, Not Rigged and Possibly For Sale!
    30' SeaRay 290 SunSport SLX: twin 3.0L Duramax diesels & Bravo3 drives
    52' Sunseeker Predator twin Volvo-Penta IPS900 diesels
    Thanks for the info on the max 5. Might try and find one...
    Jul 2021
    Pompano Beach
    I have a Bravo XS prop on my 20' Lake and Bay Backwater, with 250 SHO Yamaha it's an excellent prop with a terrific mid range, I'm running less than 5% slip in the mid range. WHICH bravo prop are you running? The XS has 8 vent holes, I run all plugged. If you're getting cavitation, your motor is too high, I can run the bravo where the tip is out of the water at high speeds and throwing an 8' high rooster tail and no slip. Getting on plane and midrange it runs best low. I would try it with a lower height first. I am spinning a 25", 4000 48mphs, 4500 56 mph, 5900 67 mph.
    It's the bravo 1, 4 blade with the vents plugged. Very similar to the XS bravo. It's on a paralift with plenty of prop in the water. Cav plate level with boat bottom at lowest position. I am thinking this prop must have a whacked blade. Thanks for the reply capt...
    Nov 2021
    N. Idaho
    Might sound weird, but I've had a couple props run like that when run to deep. Raised engine, and dropped rpm, while gaining speed.
    My theory was it was trapping air, instead of allowing the prop to vent. Just a thought.
    I agree on the idea, we have ran it hi and low with the 13'' of travel the paralift has. Trying a bravo 1 XS version this wknd to see what it does. I believe the bravo 1 we have has a blade anomaly. It just can't shed the air until about 30 mph. Raise it up any at all and it cavitates badly losing thrust and won't even get on plane. Acts like a cleavor does on my V-King.
    Nov 2021
    N. Idaho
    Good call, try a different prop.
    250xs is a popular choice for power on new bass boats. From what I've seen, alot of them are running 24p fury.
    I own a 26 fury and it's pretty small diameter, and slips alot at takeoff. I would think a Bravo would hook up well.
    See what happens soon. Running it on sat. with the Bravo xs on it.
  10. Likes OnPad liked this post
  11. #10
    Bravo XS ran out great. No slip except at throttle up, and it cleared the air fast and gets on top quick. Whole different prop than the reg Bravo 1. Bravo 1 prop 5800 r's at 58 mph. XS ran 5800 r's at 63 mph. Same pitch.
  12. Likes OnPad liked this post
  1. Scout flats/bay boat with four stroke Mercury
    By Phil Conant in forum Hulls up to 20'
    Last Post: 01-08-2015, 09:33 AM
  2. Need help with a prop on fast flats boat
    By Griffin4590 in forum Props, Setup, and Rigging
    Last Post: 05-01-2012, 01:35 AM
  3. Best prop for a flats boat
    By oldskool65 in forum Props, Setup, and Rigging
    Last Post: 06-18-2010, 05:46 PM
  4. PROLINE 183 flats boat prop questions?
    By THEFERMANATOR in forum Props, Setup, and Rigging
    Last Post: 07-09-2007, 10:12 PM
  5. PROLINE 183 flats boat prop questions?
    By THEFERMANATOR in forum Technical Discussion
    Last Post: 06-30-2007, 06:21 PM
