Results 1 to 2 of 2
    Feb 2019
    Plainview, NY
    24 Skater Engine WIDTH
    Hi,
    whats everyone running for engine width, i think stock is 49in center to center, i hear widening the stance is the way to go with 3.0 mercs with setback.
    Thank you
    Justin
    Florence, SC
    I will have to measure mine... I think the issue is keeping the props out of the tunnel and letting air escape without hindrance. I am adding fences to close off the airflow at the tunnel to the transom to increase the rear pressure and keep the waterflow ahead of the gearcase to propeller clean as well. As far as i have found, with a 20" mid, bolting it to the transom at the #4 hole was best was best. I have toyed with the idea of going to 15" Todd-Mids but then to do that I have to add setback brackets which not only defeat the weight saving going from 20" mids but now it affects the handling of the boat by setting weight back. Both of my batteries have been moved from the back of the boat to the forward bulkhead, offset centerline to the left. I am running a full weight/balance sheet on this boat as I would in an aircraft so the handling of the hull should be neutral and flat. No stereo, no rear seats... no BS!! Just twins screaming like a nightmare after prom!!
    David "Tango" Wilks
    Current boats: (Not All Running...LOL)
    18' VT-Rocket Bass Boat: 2.5L 280 Mercury
    21' Eliminator Daytona: Stripped and Possibly For Sale!
    24' Skater: Uncut, Not Rigged and Possibly For Sale!
    30' SeaRay 290 SunSport SLX: twin 3.0L Duramax diesels & Bravo3 drives
    52' Sunseeker Predator twin Volvo-Penta IPS900 diesels
  1. over all width of a 24 Skater
    By CUDA in forum General Boating Discussion
    Last Post: 04-03-2021, 11:24 PM
  2. Skater engine hight
    By Frank G in forum Props, Setup, and Rigging
    Last Post: 08-12-2010, 09:47 PM
  3. 32 skater engine height
    By baja555 in forum Props, Setup, and Rigging
    Last Post: 08-03-2010, 01:42 PM
  4. 24 skater with single engine?
    By Mike_g in forum General Boating Discussion
    Last Post: 12-13-2007, 12:56 PM
  5. 24 skater single engine?
    By Bullshot in forum Props, Setup, and Rigging
    Last Post: 05-12-2006, 12:24 AM
