Results 1 to 12 of 12
Thread: Props
    Mar 2011
    oregon wi
    Props
    Would appreciate any feedback on the best high performance prop for bow lift. Currently have several Promax props but have too much stern lift. Had the barrel cut down on one and helped but wondering if there is a better option. Have a 28 and 30 and running on a Bullet XRS with 300xs. Thanks!
    Jul 2021
    Pompano Beach
    Bravo XS gives great bow lift.
    Nov 2021
    N. Idaho
    I run a 28p signature eagle 4 blade on my 20' bullet with 200hp and it runs good without much trim.
    Bravo would be good also. Bass Boat Central has some setup info on their site.
    Is your boat loose, or just won't carry the bow?
  4. Likes rgsauger liked this post
    Jul 2021
    Pompano Beach
    Onpad- what speed/rpm are you getting with the signiature? I have a 20' lake and bay backwater with 250hp SHO Yamaha. I've heard the Bullet's are very fast boats.
    Nov 2021
    N. Idaho
    Best I've seen is 74 mph at about 59 to 6 thousand rpm, with 1.87 gears. I'm running about 2 1/2" above the bottom of the boat, with a 12 or 14" plate. Can't recall which.
    I've tried a 26p fury, 26p trophy, 28p signature eagle 3 blade, and a 26p v6 chopper all above props have to be dropped down on the plate to get enough bite and are still spinning in the mid 6 thousand rpms, and run slower mph.
    My speed doesn't really jive with what people claim at Bass Boat Central, but the bottom of my boat is beat up, due to the previous owners. I've done some repair, but it needs more.
    When I bought the boat it had a 225 EFI. Between the condition of the bottom of the boat, soft motor mounts, and no nosecone, it was almost undrivable. Actually had it blow out once.
    Sep 2017
    Ashland city tn
    Quote Originally Posted by OnPad View Post
    How much does that bullet weigh no motor u think?
    Nov 2021
    N. Idaho
    I think the specs say something like 1100-1200lbs.
  9. #8
    I live in Prineville Oregon which is in the central part of the state
    If you can borrow a big ear chopper over hub prop you might be surprised at how much bow lift a chopper generates.
    Carter Powell
  10. #9
    Jun 2018
    Floating around
    I have a bunch of choppers and they all behave so different. I think it’s because of age and prop shop work over time but the ones with lots of tailing edge cup really lift well and carry high and fast on my streams. A bit hands full to drive but I really like that it’s fun
  11. Likes rgsauger, OnPad liked this post
    Dec 2009
    middle tennessee
    My Hoss Cut Chopper carries the bow very well in my Allison with very little positive trim. Have a few clips of it in this video. You can see from the rooster tail that there is not a whole lot of positive trim being used. The last two passes in the video have two people in the boat. https://youtu.be/rIox1DB2jVc?t=489
  13. Likes LakeFever, OnPad liked this post
  14. #11
    Jun 2018
    Floating around
    That looks like a lot of fun ^
    Dec 2009
    middle tennessee
    For sure man.. That boat is the most fun I have had on the water
  1. Mercury Tech: 24 Skater with twin 300 promax Props in or Props out?
    By checkmate45 in forum Technical Discussion
    Last Post: 08-03-2017, 11:55 PM
  2. Replies: 9
    Last Post: 02-09-2016, 07:10 PM
  3. Props to Tim @ Hoss Props
    By contentsunderpsi in forum General Boating Discussion
    Last Post: 08-27-2014, 08:34 PM
  4. Mazco props? what kind of props are they?
    By dalin in forum Props, Setup, and Rigging
    Last Post: 08-20-2008, 09:05 AM
