Results 1 to 3 of 3
Thread: 97 Mariner bogs
03-08-2022, 07:08 AM #1Junior Member
- Jan 2022
- North TEXAS
97 Mariner bogs
97 Mariner EFI 200 Mag. Has compression from115 to 111 starts good runs and sounds good in the water up to 1700 or 1800 rpm, when the sound changes like its trying to open up it bogs. Have checked fuel system and besides it looking like it brand new inside it all checked out. With fuel pressure gauge installed it runs 38 psi thru the total range that it will run, pressure never dropped off. When it bogs it almost sound like it developed a miss. I brought this to repower. I have never heard it run.
03-08-2022, 08:45 AM #2
Post it in the tech section.
04-04-2022, 06:22 PM #3
IT sounds like the high speed stage of the stator is gone. I bet it starts and idles fine, and as soon as you try to open it up..booooooggg
do resistance test on the stator.ON VACATION
245 bogs a little from idle
By pappa pete in forum Technical DiscussionReplies: 17Last Post: 07-29-2015, 09:08 PM -
OMC Tech: 25 hp omc bogs down
By Fishnfool in forum Technical DiscussionReplies: 13Last Post: 06-07-2011, 11:00 PM -
2.4 200 bogs on takeoff
By jaybluez in forum Technical DiscussionReplies: 11Last Post: 12-30-2010, 07:49 PM -
2.4 200 bogs
By t.martin in forum Technical DiscussionReplies: 16Last Post: 04-09-2009, 01:06 PM -
2.4 bogs out of the hole
By Alan Power in forum Technical DiscussionReplies: 6Last Post: 06-13-2004, 09:51 PM
