Results 1 to 15 of 19
02-27-2022, 08:52 AM #15000 RPM
- Aug 2010
- Jacksonville, FL
- 144
Who works on E-tecs and has a test tank or dyno North Florida area
E-tec on a Hydrostream. Local dealers either won't work on it or won't water test it.
I'd be willing to travel as far as Orlando or Savannah.
1986 Baker 18 Mod VP, Yamaha 175
2001 Crest Pontoon, 150 Opti
1968 Sears 14' aluminum, Merc 110
02-28-2022, 08:31 AM #2
C and o marine has certified mechanics, but they are up here in tn, worked on both of my etech motors, good people
(Rip. Whiteally02) -dad
03-06-2022, 10:27 AM #35000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
If your tired of the electrical issues and it’s a 3.3 ltr you could do the ocean pro 225 swap and have 325 Hp on a stock engine I have done several swaps one engine I’ve got has 380 + hp
03-07-2022, 10:48 AM #45000 RPM
- Aug 2010
- Jacksonville, FL
- 144
That sounds like a really good idea. It's already on an earlier 3.1 mid. Do you swap the heads, carb setup and electrical onto the etec or do you swap the entire powerhead?
It's my son's boat. He's still embracing the green idea but rapidly getting disgusted.
03-07-2022, 08:51 PM #5
A lil farther but track down bajamerc on here.
He has forgotten more about e-tec’s than we will ever learn.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
oldschoolltv, specboatops liked this post
03-07-2022, 10:06 PM #6Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7151
- 3 Post(s)
I agree with Gary. Call Kevin, those were his babies for a long time until recently when he has decided to go to the dark side (mercury) with four strokes.
Instigator liked this post
03-08-2022, 06:34 AM #7I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
powerabout liked this post
03-08-2022, 09:40 AM #85000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
Well I’ve done this swap it’s fairly straight forward keep the 3.3 if you just want to have a easy fix one afternoon of work here are the bits you can keep the heads just remove the injectors and leave the nozzles attached remove throttle body’s flywheel and upper bearing Swap over entire harness and regulator keep fuel pump and filter remove everything else install carbs 225 preferably rejet to .84 mains also open up float bowl seats to 1/16 drill bit or reamer / stock block will preform good with stock head would have to go up in pitch 1 or 2 inches on prop stock block needs this removed and ports cleaned up and exhaust raised to 1.69 from deck of block with cut for dome pistons on ocean pro heads then this engine will run better and more efficient with about 350 Hp and torque @ 6700 … to get more than that you need a good port job and long rods forged pistons then you can rev to 8 k and make big power DBR sleeves are the way to go to get there they already did all the work 385 on carbs isn’t bad for old school I run BUHW NGK plugs in mine idles like a ocean pro smooth with smokeless XD100 50/1 port casting removed
03-08-2022, 09:56 AM #95000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
Also some Carson reeds are a good ticket to do wile messing with it those reed changes are the time consumer but well worth it for smooth running and power
03-08-2022, 06:45 PM #10I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Speed Jr. liked this post
03-08-2022, 07:30 PM #11
Etech motors are the hardest motors to do anything with, if you really wanting to turn it up, you basically have to go all the way down and rebuild it from the bottom up is what Monty racing told me, get ready for about 35 k for them to do it with a cut mid
03-09-2022, 08:21 PM #12Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
I dunno, with today’s gas prices, my 200XS and 150 HO Etec look pretty good
03-09-2022, 11:47 PM #135000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
This is tru if you rely on making a living on the water:/ it’s no different if you had a chevell SS you only use it when you want but to buy a new one and let it sit 6 months to use it makes no sense to buy and watch it depreciated / any running over 4K fuel consumption is really close they are efficient down low rpms but when they came out carb for 12 k or 15 k for opti /do 3 k is a lot of fuel to use would take the average boater 7 8 years so my opinion is if there is lost power to push around I’d rather have it on reserve at the blip of throttle am be propped for the extra horses and cruse efficiently then be stuck with limited horsepower you can’t tap because it would cost you more than a gasket set and some carbide burrs at 10 each and some sanding cones for 40 kit tear it down zip lock and number everything and make a extra 100 Hp if you just make every rod and piston wt uniform within 1/2 gram that winter project would rip some water up and when you see how much power is on tap with something you did it’s very rewarding to have a beast that seems to be stock but isn’t ..all air moving thru a 2stk will turn a corner but the fuel won’t it puddles and limits power so radius the path an get efficiency and power a Winn Winn
03-11-2022, 07:35 AM #145000 RPM
- Aug 2010
- Jacksonville, FL
- 144
Thanks Mr. G my son and I are already working on this mod. When you say .84 mains do you mean #84 main jets or to drill them out to .084? How about if we just got main jets from a 300?
03-11-2022, 07:42 AM #155000 RPM
- Aug 2010
- Jacksonville, FL
- 144
need dyno to test motor
By bill6ft6 in forum Technical DiscussionReplies: 6Last Post: 11-19-2017, 05:41 AM -
e-tec 150ho dyno test
By Bjorn in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 14Last Post: 09-09-2015, 12:15 PM -
Dyno services in Mid West area.
By Capt.Insane-o in forum General Boating DiscussionReplies: 15Last Post: 02-02-2013, 11:51 AM -
Houston area dyno service
By Matt in forum Technical DiscussionReplies: 2Last Post: 07-03-2001, 10:04 PM
