Results 31 to 44 of 44
Thread: Vector setup
04-02-2022, 10:49 AM #31
I've never been a fan of a cleaver on my Viking. Had good luck with choppers, SRX, and my favorite and best for my rig is a 30ET.
It does seem that they guys well over 100 tend to like the cleavers. Mine runs mid 90's and just feels very loose to me with my cleaver. But that prop has been worked and seems pretty thin.
The SRX and choppers just needed a bit more driving, tended to walk a bit more.'78 Hydrostream Viking/'98 225 ProMax
Asstracker liked this post
04-02-2022, 01:42 PM #32
How high above the pad are you running your prop shaft Tnels?
08-17-2022, 10:46 AM #33Member
- Nov 2018
- lancaster, Pa
- 85
- 11
- 58
- 22
Update to all that had input. Motor is about 3/4 - 1" above the pad, i havent checked exactly and am just going off water pressure and where it was when i first checked. I think i have a little more room to play with on my motor height as i get 25+ psi at WOT.
With the new case i got 92 at 7000 on a humid 98 degree day. i havent changed the setup since this run. i believe with another 1/8-1/4" i'll still have enough water pressure to keep cool on a normal day. also should be able to spin my motor another couple hundred rpms with cooler air.
i found around 50-60 lbs sat in the rear port side of the boat balanced it best for driving solo.
still running the 28 et cut chopper
scott reierson thanked for this postLakeFever liked this post
08-17-2022, 12:14 PM #34
08-17-2022, 11:08 PM #35
Just saw this, sorry. I'm 3/4" above the pad at the moment. I hung the motor on the lowest hole last fall and tried it close to 2" above. Seems like I just got more slip, didn't get any more speed. I feel like it wanted to walk more too.
OP, my boat loves 50lbs of led shot in the far back left wing when I'm solo. Night and day without it.
Seems we're both on that quest to break 100!Last edited by tnelsmn; 08-17-2022 at 11:11 PM.
LakeFever, scott reierson thanked for this postLakeFever liked this post
08-30-2022, 10:03 AM #36Member
- Nov 2018
- lancaster, Pa
- 85
- 11
- 58
- 22
08-30-2022, 10:33 AM #37
This is where you gotta get careful. 100 mph with 200 horsepower is impractical. Too many guys tried getting there with the "up" button and regretted it. In real life, upper 90's is about it. Of course, there's plenty of people running 100 on the internet with 175's, and I believe every one of em
09-01-2022, 10:55 AM #38Member
- Nov 2018
- lancaster, Pa
- 85
- 11
- 58
- 22
10-10-2022, 09:36 AM #39Member
- Nov 2018
- lancaster, Pa
- 85
- 11
- 58
- 22
I wanna break that barrier before I sell and get in a tunnel.[/QUOTE]
Well, looks like im not going to be breaking that barrier. Boat is for sale for anyone interested. more info on FB marketplace(area 17512) or in a couple of the racing groups. Thank you to everyone for the input
10-10-2022, 11:25 AM #40
Kids
10-10-2022, 11:29 AM #41Member
- Nov 2018
- lancaster, Pa
- 85
- 11
- 58
- 22
10-10-2022, 07:36 PM #42
Put a Mazco RE-4 in 30 pitch on it you will lose RPM and gain MPH
10-10-2022, 07:39 PM #43
Put a Mazco RE-4 in 30 pitch on it you will lose RPM and gain MPH.Be careful how much positive trim you run till you are very used to it,with the right prop it will carry the bow without lots of positive trim,flat is faster than flying the bow real high.The 20 ft Vegas below was 82 all day with that big old 235 fishing mota.
01-20-2023, 02:35 PM #44New Member
- Nov 2021
- Maryland
Wear a great life jacket!
Vector setup
By mrconcrete in forum Props, Setup, and RiggingReplies: 26Last Post: 07-08-2012, 09:52 PM -
What's your Vector setup.
By gdp in forum Props, Setup, and RiggingReplies: 7Last Post: 04-20-2012, 07:16 AM -
Vector setup???
By Skittles in forum General Boating DiscussionReplies: 42Last Post: 02-22-2003, 01:59 PM -
86 Vector Setup?
By fredsav in forum Technical DiscussionReplies: 34Last Post: 12-09-2002, 10:57 PM -
Setup for a Vector
By ScottyG in forum Technical DiscussionReplies: 3Last Post: 08-10-2001, 04:55 AM
