Results 16 to 30 of 44
Thread: Vector setup
    Quote Originally Posted by Asstracker View Post
    Matt daggetts my pops
    Got it. I get all you Pennsylvania guys mixed up Bring that thing up here, we'll get ya fixed up.
  2. Likes Asstracker liked this post
  3. #17
    Mar 2004
    Brooklyn Park, MN
    One quick question would be is the bottom nice and flat on the pad and outside that area as well in the last 3-5 feet? The smallest hook will keep the boat on the water and not let go. Just something to check. Or your prop may not be a 28P?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. #18
    Nov 2018
    lancaster, Pa
    bottom was blueprinted in when it was redone. prop was a 28 chopper cut to the specs of a 28 et with a little cup for stern lift.
  5. #19
    Mar 2022
    Azad Kashmir
    be careful bro, and don't forget to wear life jacket!
  6. Likes rgsauger, Asstracker liked this post
  7. #20
    Nov 2018
    lancaster, Pa
    to everyone who commented:
    Got a stock case with a cone w/ the hose on both sides so it should get plenty of pressure now. 1.87 gears with everything went through and has not touched water. Old case is sold pending pickup as of now.
    Also, I have a lifeline I wear whenever I'm going for top end. Normal riding calls for a more comfortable vest but more than not I have a life vest on. and its always in the boat.
    I also have a 28 chopper that came into my possession and haven't heard many good things about choppers on streams but would like to know what you guys think about me running it. I would like to try It but is there anything I should watch out for? will it make my boat handle drastically different?
    Thanks, Noah
  8. #21
    Thanks, Noah
    At the MOST, about 10% of what you hear and "what everybody knows" is accurate. The rest is all just total crap. Most of these "experts" have never even run what they're spouting off about. A Chopper works just fine on a Stream. My only beef is with some stock ones they start to run out of bite when you get well above the pad, so raising the motor won't increase the speed much if at all. Should be pretty easy to get to 90+ with what you have now.
    You'll want to keep trying different props for fine tuning and to find what feels best for you.
  9. Likes Asstracker, rossi liked this post
  10. #22
    Nov 2018
    lancaster, Pa
    thanks again for your input. I got a little work to do to my boat and hopefully some time for a test and tune before June. gotta put an offshore tiller arm and move my motor up a hole so I can get more use out of my jackplate. then hopefully see some big numbers.
    best regards and hopefully see you in June,
    Noah
  11. #23
    Nov 2018
    lancaster, Pa
    also just picked up a little 24 chopper on the cheap so ill have a sandbar hopper. should be nice for when I have the woman, a full cooler, and a bunch of extra stuff lol
  12. #24
    To get the best numbers you'll need to get a good bit higher, 1 1/2 to 2" above the pad. Might want to think about a redrill or different style plate for more height.
    Nov 2018
    lancaster, Pa
    I think I have about 1 and 1/2 to 1 and 3/4" to play with. the jackplate still has a little over an inch that it can go up and I'm on the second from bottom hole on the clamp. I might be able to stretch it to 2" above the pad with all of that but ill have to see.
    I had to redrill the plate to move it up just about as high as I could get it when I bought the boat. I made it as high as It would go and still get the mounting bolts in at the angle.
  14. #26
    Central, PA
    Asstracker, swap over to a cleaver prop....I messed around with all sorts of choppers, rakes, round ears....etc. As soon as I put my first mazco cleaver on... no more pull, half the chine walk, and top end really woke up
  15. Likes Asstracker, Dd24skater liked this post
  16. #27
    Jun 2018
    Floating around
    I met a guy recently who has a dozen streams and he also vouched for the cleaver being the best. I haven’t run one yet, seems a bit counter to lift the stern on a stream. Anyone experience blow out with cleavers on v hull streams?
  17. #28
    With his bottom being blueprinted he might benefit from a little stern lift if the hook was removed.
    Nov 2018
    lancaster, Pa
    I tried a cleaver with my old setup. was the first time I drove the boat but I didn't like it. The next time out with the et it drove like a completely different boat. And if you're referring to the hook that came from the mold I believe that started a couple years after my boat was made in '78 when the molds warped.
  19. #30
    Drive it with what you're comfortable with, nobody else's ass can tell yours how it should feel. High speed operation requires absolute confidence in yourself and your setup. You can't operate with confidence if it doesn't feel right.
    Most of the cleaver cheerleaders are running big horsepower, and that makes perfect sense because the faster you go, the boat lifts itself and doesn't require any help from the prop. A 90 mph boat doesn't always want what a 105 mph boat wants.
    I would walk away (maybe run) from ANYBODY who says there's only one way to run, or one prop to run on a Stream, because it demonstrates spectacular ignorance.
    I have no tolerance for the "Run what I do or your boat will suck" crowd.
  20. Thanks Asstracker thanked for this post
    Likes Asstracker, LakeFever liked this post
  1. Vector setup
    By mrconcrete in forum Props, Setup, and Rigging
    Last Post: 07-08-2012, 09:52 PM
  2. What's your Vector setup.
    By gdp in forum Props, Setup, and Rigging
    Last Post: 04-20-2012, 07:16 AM
  3. Vector setup???
    By Skittles in forum General Boating Discussion
    Last Post: 02-22-2003, 01:59 PM
  4. 86 Vector Setup?
    By fredsav in forum Technical Discussion
    Last Post: 12-09-2002, 10:57 PM
  5. Setup for a Vector
    By ScottyG in forum Technical Discussion
    Last Post: 08-10-2001, 04:55 AM
