Results 1 to 11 of 11
    Oct 2015
    Kentucky lake
    Cool Merc oil vacuum line routing?
    I've recently got a Merc 2.4 carb motor and the previous owner decided he was going to mix match some random ass hose combinations. So, I ripped it all off. Start over fresh. Can someone send me a picture of each side or a diagram of each side so I can continue re-pluming my new tygon yellow 1/8" fuel hose. Thanks.
    Oct 2015
    Kentucky lake
    6 hose lines by the way thanks
    Houston, TX
    I’ve got a 2.4, too. Can send pics of the manual tomorrow
    Sep 2006
    Key Largo, Fl
    On each side,intake to cylinders
    top to bottom,bottom to middle,middle to top,Chris
  5. Likes rgsauger, powerabout liked this post
    TX......somewhere?
    try these.....
    Attached Thumbnails Attached Thumbnails V6 bleed lines (starboard).jpg   V6 bleed lines.jpg
    Sep 2006
    Key Largo, Fl
    try these.....
    If it was a 2.5,He asked about a 2.4,Chris
    TX......somewhere?
    which ones are different?
  9. #8
    Sep 2006
    Key Largo, Fl
    As your diagram...
    Going from cylinder to front,P port,S starboard
    P2-S5
    P4-P1
    P6-P4
    S1-S3
    S3-P6
    S6-S2
  10. #9
    TX......somewhere?
    gottcha, but it still works jus fine on either 2.4 or 2.5.. least it did for my junk........... those drawings jus say V6?
  11. #10
    Sep 2006
    Key Largo, Fl
    On a 2.4 the port intakes feed the port cylinders,starboard intake feeds starboard cylinders,on a 2.5 a couple hoses change sides,Chris
  12. #11
    TX......somewhere?
    i've always "crossed" tha things on both.. don't remember why.. didn't have drawings back then.... learned 'bout "bleeds" with a formula motor which had 12 bibs on front half! was fun for tha first time seein' it......
  13. Likes rgsauger liked this post
  1. Mercury Tech: Where do I connect this vacuum line? ( '89 Merc 150 V6 w/ Carbs)
    By pjbrownva in forum Technical Discussion
    Last Post: 03-15-2017, 03:40 PM
  2. vacuum hose routing
    By madatnumbers2 in forum Technical Discussion
    Last Post: 08-12-2014, 04:46 PM
  3. Mercury Tech: 250 VST vacuum routing
    By johnsinbelton in forum Technical Discussion
    Last Post: 02-23-2010, 06:10 PM
  4. help with bleed line routing on merc 200hp efi
    By stoker2001 in forum Technical Discussion
    Last Post: 06-28-2005, 04:28 PM
  5. Merc bleed line routing?
    By CDave in forum Technical Discussion
    Last Post: 06-15-2004, 04:12 PM
