Results 1 to 5 of 5
    Nov 2009
    Netherlands
    Fishing V6 piston clearance 2.0 vs 2.5
    I'm looking at the specs in my manual for Mercury V6 135 150 175 200 225 (1992 up)
    105 Jet/135/150 (2.0 liter):
    Cylinder bore: 3.125"
    Piston: 3.115 +/- 0.002"
    Thus clearance is 0.008" - 0.012"
    XR6/MAGIII/175/200 etc (2.5 liter):
    Cylinder bore: 3.501"
    Piston: 3.494 +/- 0.001"
    Thus clearance is 0.006" - 0.008"
    Why is the piston clearance so much higher on the 2 liters? Anyone can explain?
    Pekin, IL
    Maybe sleeve thickness.
    Rock
    Team Junk
    Nov 2021
    N. Idaho
    That's weird, you would think it would be the other way around by .001 or .002
    12 thousandths would be pretty sloppy. 2.0 may be a good motor to run forged pistons in. Although I do have one that squeaked a piston out in the shop. I think someone ran it out oil or water though.
    Nov 2021
    Holland,Michigan
    I have a clearance of . 01 to . 012 on my 88 2.0 black Max is that acceptable. I'm going to hone and ring it.
    They are Wiseco pistons.
    Is that too much?
    1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
    With a need for speed!!
    Nov 2021
    Holland,Michigan
    Quote Originally Posted by SJD1974 View Post
    Is that too much?
    I made a mistake I measured at the top of the piston and not at the ristpin height.
    Im at. 007
  1. OMC Tech: piston clearance
    By moldman in forum Technical Discussion
    Last Post: 04-07-2013, 06:50 PM
  2. 2.4 cyl & piston clearance
    By woody in forum Technical Discussion
    Last Post: 05-08-2007, 07:57 PM
  3. Piston Clearance
    By OWENS1 in forum Technical Discussion
    Last Post: 02-06-2006, 11:02 AM
  4. Piston clearance
    By tony nc in forum Technical Discussion
    Last Post: 11-20-2002, 09:14 PM
  5. 2.5 piston clearance
    By Marcus in forum Technical Discussion
    Last Post: 03-21-2002, 09:26 AM
