Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    Jul 2004
    Connecticut
    Would be super interesting to hang this V6 200 APX motor on a scale to get a true weight.
  2. Thanks Instigator thanked for this post
    Likes Instigator liked this post
  3. #17
    Feb 2016
    modesto ca
    We have tested the Opti and the APX at Bakersfield so we have lots of Data. Mercury did a good job at making the APX equal to the Opti. As of now the lap times are a little better with our Opti. We are working on it as we speak. The rpm is different. However the prop shaft is the same RPM as the Opti. So our props work on the APX. We never stop working with props. We haven't even tried our 5 blade yet????? He was turning W.O.T. just like the Opti.
  4. Thanks Instigator, scott reierson thanked for this post
  5. #18
    Jul 2004
    Connecticut
    Tim, you are comparing to the Gen 2 200XS ROS correct?
  6. #19
    Feb 2016
    modesto ca
    Optimax weighs 395 with oil bottle and 2 gallons of oil 415 for the APX.
  7. Thanks Greg G thanked for this post
  8. #20
    Feb 2016
    modesto ca
    2ooxs sst.
  9. #21
    7 Post(s)
    Wow.
    Same props, at same prop rpm as before, 20 lbs heavier and already close on lap times????
    Badd Ass!
    Please continue sir.
    Hats off to Merc.
    Like it or lump it, technology moves on.
    There will always be classes for our old stuff.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  10. #22
    May 2001
    Madison, WI
    Wow, Very cool! Thanks for posting.
    Wonder what a pack of those will sound like in a race. Same prop shaft speeds. Amazing. That 5 blade could be the ****.
  11. #23
    Sep 2017
    ontario
    I have a 2012 XS gen 2 opti and i believe my rpm limit is 7200 and produces a strong pull from 6800 to that 7200.
    Not at all trying to nix the thread or the new motor - just trying to state the fact of the rpm .
  12. #24
    Feb 2016
    modesto ca
    Our Opti limiter is 8000 and we would hit it every straightaway, Now the APX limiter is 6800 RPM however the prop shaft RPM is the same or real close to it. In other words the gear ratio is different. As for now we are not hitting the limiter with the props we have. When we tested in Parker with there motor that had 60 hrs. on it. We tested 12 props and some of them hit the limiter. We are still dialing it in. I hope you get what I'm saying sometimes I have a hard time saying things right. The reason your Opti is 7200 rpm is you are not running the Opti 200xs SST.
  13. #25
    Jul 2004
    Connecticut
    Quote Originally Posted by timking57 View Post
    You said everything right in my book. Thanks for the inside info. It sounds like the new APX V6 powerhead is strong. I may be wrong but I thought the SST 200XS Opti 2.5 made around 247 horsepower but had the higher 8,000 rpm ECU unlike the 200XS ROS.
  14. #26
    Feb 2016
    modesto ca
    I'm not sure about the horse power. I guess you could ask someone that has put it on a dyno. It's even hard to believe Mercury after all they said the Opti weighed 300 pounds. They made the APX with a gearbox that has 4 different gear ratios. They ended up using the highest gear ratio. I don't know if you can get the other gears. However the three lower gears won't do you much good our courses are to short. The 360 APX also has a gearbox. I'm not sure what gear they use.
  15. Likes Greg G liked this post
  16. #27
    Feb 2016
    modesto ca
    Here is the difference between the Opti and the APX starts.
    https://www.youtube.com/watch?v=KH4RwLE-_W4
    https://www.youtube.com/watch?v=RmV96427204
    Here are all three motors running together. We ran that same motor the next day. That's when we ran through all the props. And his lap times were the same as his Opti.
    https://www.youtube.com/watch?v=r0UbO07j6C4&t=13s
  17. Likes Speed Jr. liked this post
  18. #28
    Lake Coochiching, Ontario
    Quote Originally Posted by kellytheaker View Post
    I have not probed the rev limiter on my 200XS. I need to put on one of my smaller prop and hit the up buttons (trim, jackplate). I've been close to 6800 but never pushed harder.
  19. #29
    Feb 2016
    modesto ca
    Innless you are racing I would say not the best thing for it. We hit the limiter on every straight a way. We were also changing reeds after every race. Not really cheap. We also go through a lot of props.
  1. where it started for me
    By David in forum General Boating Discussion
    Last Post: 10-09-2021, 05:49 PM
  2. Optimax Fuel Rail Pressure Testing, Leak Testing & Calibration
    By InjectorService in forum Technical Discussion
    Last Post: 12-22-2020, 10:44 AM
  3. Video: CRT Testing Stock F1 today! Testing modified F1 on Saturday!
    By caldwellrace in forum General Boating Discussion
    Last Post: 03-26-2020, 01:11 PM
  4. Well Sh*t .... I started another one
    By NICE PAIR in forum Fiberglass and Composites Discussion
    Last Post: 03-15-2019, 08:31 AM
  5. All done but getting started.
    By Damyankee in forum General Boating Discussion
    Last Post: 12-16-2008, 08:02 AM
