Results 1 to 6 of 6
    Apr 2007
    Texas
    300XS Leaking Tilt Ram
    I have an early 300XS with the 3 ram tilt and trim. The tilt ram (center one) is leaking on the top cap seal around the ram. My dealer says parts are NLA and Merc wants to sell the whole T&T assembly. Anyone know where a seal kit might be found? What are my options?
    Thanks!
    Feb 2011
    HUDSON, FLORIDA
    ive purchased seals from a local hydraulic repair shop, heavy equip stuff. they had all kinds, hundreds of em.. worked for me.
  3. Likes Forkin' Crazy liked this post
    Jun 2018
    Floating around
    I’ve had this a couple times and solved it with Lucas transmission fix. It softens the seals and stopped the leaks. Sounds like a hack job but it worked good for me. Lasted many years too.
  5. Likes KIRCHNER liked this post
    NE Louisiana
    Don't use snake oil. It never works in the end.
    Like I have sourced seals for my Seastar steering, your local hydraulic shop. Just don't tell them what it is for.
    Nov 2009
    Netherlands
    Same here, local hydraulic shop can almost always pick the right seals for you (at a fraction of the cost compared to Merc).
    Jun 2018
    Floating around
    There’s nothing snake oil about it. Got dry hands? No need to replace your skin just add some lotion and your good to go. Rubber dries out, adding some lotion to soften them up isn’t going to hurt a thing. Hydraulic fluid is all basically the same it’s the additives and viscosity that are the differences.
    suit yourself it’s a lot of work to tear these apart and you won’t hurt a thing trying the Lucas first.
  9. Likes KIRCHNER liked this post
  1. Mercury Tech: 3 Ram Tilt / Trim Leaking Down
    By wcsd106 in forum Technical Discussion
    Last Post: 02-17-2019, 02:37 PM
  2. Trim/Tilt leaking down overnight
    By bouyhead in forum Technical Discussion
    Last Post: 12-07-2017, 07:22 PM
  3. Mercury Tech: tilt/trim cylinders leaking
    By ls7colorado in forum Technical Discussion
    Last Post: 06-07-2009, 05:37 PM
  4. Tilt Leaking Down
    By FOXCRAFT0923 in forum Technical Discussion
    Last Post: 08-16-2008, 09:48 PM
  5. OMC V4 tilt cylinder leaking at pigtail
    By Riverman in forum Technical Discussion
    Last Post: 07-11-2007, 07:39 AM
