Results 1 to 10 of 10
Thread: 2.4 EFI drop on
01-16-2022, 01:42 PM #1
2.4 EFI drop on
Crankcase injected 2.4L drop on for sale. Going to a 2.5L and dont need spare powerheads everywhere...
This motor has 2 or 3 hours on it since being rebuilt.
Weight matched pistons & rods +/- 1.5g (cast, I believe ART but not 100%)
Angle cut intake
Slightly opened exhaust chest
9 ring crank, all new crank bearings and seals
Aluminum flywheel
Composite 1" reed spacer
CCMS reeds
Head studs
Right now it has 22cc heads and I'm running 97 octane at 23° timing. If you would like to run pump gas I will put a set of factory heads on it.
$5000 obo depending on where its going...local pickup I may come down on price so I dont have to crate it up...Jacob 510-418-4911
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
02-06-2022, 02:02 PM #2
To the top...this is a strong running 2.4 that you don't have to worry about burning the bridges out of...
02-08-2022, 09:32 AM #3Member
- Sep 2021
- Buffalo, NY
- 88
- 304
- 18
I dont have the available funds (wish i did) but in the future if i wanted to upgrade would this be an easy swap with my xr4 head?
02-08-2022, 09:33 AM #4Member
- Sep 2021
- Buffalo, NY
- 88
- 304
- 18
I dont have the available funds (wish i did) but in the future if i wanted to upgrade would this be an easy swap with my xr4 powerhead?
02-08-2022, 10:05 AM #5
Yes. Powerhead looks good Jacob.
RockTeam Junk
02-08-2022, 05:12 PM #6
Yeah it would be a nice upgrade from a xr4. About 100 more hp!
03-22-2022, 06:02 PM #7
Would love this, just need it to fit under a Clamshell
03-23-2022, 02:45 PM #8
I bet you could make it fit actually. It has the exhaust divider with tabs for the cowl mounts, so all you would have to do is cut two half moons in the front for the horn to stick through and put rubber pull latches to strap the top and bottom. Then take the face plate and put 1" spacers on it so it can be a splash guard for the front...
I've been thinking about doing it for a while but never got around to it.
05-03-2022, 10:53 AM #9Junior Member
- Nov 2021
- Mi
- 21
could i get your #
05-03-2022, 12:41 PM #10
1- 2.5 drop on, 1- 2.4 7 petal drop on, Alian cowls, chassis, lowers and more....
By motion 110 in forum Outboard EnginesReplies: 1Last Post: 10-30-2015, 06:03 PM -
rebuilt 2.5 200 hp Mercury drop on powerhead rebuilt 2.5 200 hp Mercury drop on power
By Eagle One in forum Outboard EnginesReplies: 1Last Post: 03-21-2015, 09:19 AM -
WANTED: Looking for drop down/ drop out/ stand up bolster seats
By baja200merk in forum Parts WantedReplies: 0Last Post: 01-05-2014, 09:12 PM -
how many things can be mis represented on a drop on before its not a drop on
By Dutch in forum General Boating DiscussionReplies: 67Last Post: 10-08-2009, 02:17 PM
