Results 31 to 35 of 35
01-18-2022, 09:29 AM #31
You will be amazed when you start playing with engine heights as others have suggested. At first, jack it up an inch and see what it does. If it likes it, go another inch. When you start getting close to perfect, you will be moving it in 1/4" increments (6mm). Big changes on the front end just help get there faster. You may already be perfect...but the only way to know is to experiment. An adjustable jack plate makes it quick and easy to make changes and play with heights. Good luck!
01-18-2022, 11:25 PM #32Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Dixicup..............Thing About that hull is a shallow V.........don;t want to dance with trim/jacking.........
01-20-2022, 03:18 PM #33
01-29-2022, 08:15 AM #345000 RPM
- Jul 2021
- Pompano Beach
- 144
- 16
- 38
Your motor should be rated 5000-5500 rpms max speed, if I remember correctly. I don't think 5600 would hurt a thing. You could always have a little cup added to your prop by a good prop shop. BUT, the speeds you're getting are REALLY good for the power, I'd tend to leave it alone.
02-03-2022, 04:49 AM #35Junior Member
- Jan 2022
- Italy
- 16
Sst 120 - propeller shaft height
By Eprotzeller in forum Technical DiscussionReplies: 3Last Post: 01-28-2021, 12:46 PM -
Outboard height on a Panther
By Extreme in forum Props, Setup, and RiggingReplies: 0Last Post: 08-29-2013, 09:00 AM -
Outboard mounting and Propeller help PLEASE!!!!!!
By jdewaard in forum Technical DiscussionReplies: 5Last Post: 01-06-2013, 09:40 AM -
Outboard Height
By Enforcer2 in forum Props, Setup, and RiggingReplies: 10Last Post: 09-15-2006, 08:18 PM -
Adjusting outboard height
By Oilpig in forum Props, Setup, and RiggingReplies: 2Last Post: 03-23-2004, 08:12 AM
