Results 16 to 30 of 35
    Nov 2021
    N. Idaho
    I agree with rock and Jimboat. It looks like your setup is good. I even think you rpm is about right. If you want to drop your rpm you can add a little cup to the trailing edge of prop or go up 1" pitch on propeller.
  2. Thanks Marco128 thanked for this post
    Likes Marco128, Jimboat liked this post
  3. #17
    As Jim said you are close to the optimum for your set up, at this point you need to fine tune with trying different engine heights and may need to get a different prop.
  4. Thanks Marco128 thanked for this post
  5. #18
    Aug 2019
    Palmharbor
    In South Florida back in the 80 we use a Dixie cup from water cooler or snow cone cut a V in it and fill it with marine TX epoxy and shape it like a mercury cle case ..= 5 MPH increase also caked a bond nose cone FYI
  6. Likes rgsauger, wetsetmarine liked this post
  7. #19
    Mar 2013
    Sunshine Coast, Queensland
    I wouldn't increase the pitch on the prop. 5600 is pretty much perfect for that engine. At 5200, you will be overloading it and risk damage.
  8. Likes Marco128 liked this post
  9. #20
    Jan 2022
    Italy
    Are you talking about a handcrafted nose cone without seacock? I've heard below 75 mph slow down
  10. #21
    Quote Originally Posted by Marco128 View Post
    They do more so if you need positive trim to get best speed.
  11. Likes Jimboat liked this post
  12. #22
    Aug 2019
    Palmharbor
    Not a big cone just small one omc cases are not streamlined like Yamaha and mercury they are thick at the leading Click image for larger version.
  13. #23
    Jan 2022
    Italy
    I understand, I have a neutral trim at top speed, I don't need a positive trim
  14. #24
    Jan 2022
    Italy
    Quote Originally Posted by MrG View Post
    This is a nice project
  15. #25
    Aug 2019
    Palmharbor
ID:	499874Most low water pickups are surfing the case but 4 below Bottem this little time working gave 4 mph
  16. #26
    Jan 2022
    Italy
    Quote Originally Posted by wettek View Post
    You say?? Even if Da booklet should it do 5200 rpm?
  17. #27
    Jan 2022
    Italy
    Great, then I'll get to work right away and I'll do it the same
  18. #28
    Mar 2013
    Yes. 5200 is minimum. 5600 is pretty much perfect for that engine.
  19. Thanks Marco128 thanked for this post
  20. #29
    Houston, TX
    Would it be easty to space your motor away from the boat about 3”-4” and see how she did? You might be able to go back and up and get better overall performance.
  21. #30
    Jan 2022
    Italy
    Now I have a fixed lift of 3 inches, they are a bit small, I never tried to put an additional thickness, I wanted to add a rigid pvc plate of 1.5 inches, as you said:Concordo:
  1. Sst 120 - propeller shaft height
    By Eprotzeller in forum Technical Discussion
    Last Post: 01-28-2021, 12:46 PM
  2. Outboard height on a Panther
    By Extreme in forum Props, Setup, and Rigging
    Last Post: 08-29-2013, 09:00 AM
  3. Outboard mounting and Propeller help PLEASE!!!!!!
    By jdewaard in forum Technical Discussion
    Last Post: 01-06-2013, 09:40 AM
  4. Outboard Height
    By Enforcer2 in forum Props, Setup, and Rigging
    Last Post: 09-15-2006, 08:18 PM
  5. Adjusting outboard height
    By Oilpig in forum Props, Setup, and Rigging
    Last Post: 03-23-2004, 08:12 AM
