Results 16 to 30 of 35
01-16-2022, 11:21 AM #16
I agree with rock and Jimboat. It looks like your setup is good. I even think you rpm is about right. If you want to drop your rpm you can add a little cup to the trailing edge of prop or go up 1" pitch on propeller.
01-16-2022, 12:50 PM #17
As Jim said you are close to the optimum for your set up, at this point you need to fine tune with trying different engine heights and may need to get a different prop.
01-16-2022, 03:28 PM #185000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
In South Florida back in the 80 we use a Dixie cup from water cooler or snow cone cut a V in it and fill it with marine TX epoxy and shape it like a mercury cle case ..= 5 MPH increase also caked a bond nose cone FYI
rgsauger, wetsetmarine liked this post
01-16-2022, 05:48 PM #195000 RPM
- Mar 2013
- Sunshine Coast, Queensland
- 188
- 47
I wouldn't increase the pitch on the prop. 5600 is pretty much perfect for that engine. At 5200, you will be overloading it and risk damage.
Marco128 liked this post
01-16-2022, 06:19 PM #20Junior Member
- Jan 2022
- Italy
- 16
Are you talking about a handcrafted nose cone without seacock? I've heard below 75 mph slow down
01-16-2022, 06:22 PM #21
Jimboat liked this post
01-16-2022, 06:24 PM #225000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
01-16-2022, 06:27 PM #23Junior Member
- Jan 2022
- Italy
- 16
I understand, I have a neutral trim at top speed, I don't need a positive trim
01-16-2022, 06:29 PM #24Junior Member
- Jan 2022
- Italy
- 16
01-16-2022, 06:34 PM #255000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
01-16-2022, 06:53 PM #26Junior Member
- Jan 2022
- Italy
- 16
01-16-2022, 06:56 PM #27Junior Member
- Jan 2022
- Italy
- 16
01-16-2022, 07:01 PM #285000 RPM
- Mar 2013
- 188
- 47
Yes. 5200 is minimum. 5600 is pretty much perfect for that engine.
01-18-2022, 12:18 AM #29
Would it be easty to space your motor away from the boat about 3”-4” and see how she did? You might be able to go back and up and get better overall performance.
01-18-2022, 08:05 AM #30Junior Member
- Jan 2022
- Italy
- 16
Now I have a fixed lift of 3 inches, they are a bit small, I never tried to put an additional thickness, I wanted to add a rigid pvc plate of 1.5 inches, as you said:Concordo:
Sst 120 - propeller shaft height
By Eprotzeller in forum Technical DiscussionReplies: 3Last Post: 01-28-2021, 12:46 PM -
Outboard height on a Panther
By Extreme in forum Props, Setup, and RiggingReplies: 0Last Post: 08-29-2013, 09:00 AM -
Outboard mounting and Propeller help PLEASE!!!!!!
By jdewaard in forum Technical DiscussionReplies: 5Last Post: 01-06-2013, 09:40 AM -
Outboard Height
By Enforcer2 in forum Props, Setup, and RiggingReplies: 10Last Post: 09-15-2006, 08:18 PM -
Adjusting outboard height
By Oilpig in forum Props, Setup, and RiggingReplies: 2Last Post: 03-23-2004, 08:12 AM
