Results 1 to 13 of 13
Thread: Merc Question
    Oct 2015
    Kentucky lake
    Cool Merc Question
    Hey guys, Got a easy question,
    Will all Merc exhaust coil plates interchange?
    I've got a 2.5 that I'm wanting to use the plate off a 2.0 or 2.4 to mount my coils to, like on a 16amp setup.
    Nov 2009
    Netherlands
    Fat block and non-fat black exhaust dividers do not interchange.
  3. Likes Forkin' Crazy, Keaten liked this post
    No, as was said fat and non fat block different, 2.4 and early 2.0L are 2 piece and some have water cooled regulators.
  5. Likes Forkin' Crazy, Keaten liked this post
    TX......somewhere?
    tha only ones that work as straight bolt on, for coils and all, are tha high performance 2.5 stuff.. promax/260 etc... (only ones with boss's for tha coil mounts).. if thats what ya tryin' ta accomplish?
  7. Likes Keaten liked this post
    Oct 2015
    Kentucky lake
    Yes, I'm tryin to find one to use on a 2.5 that will allow me to mount the coils to it flat. No bracket with studs and spacers
    Aug 2019
    Palmharbor
    Look in my posted forsale pic exhaust plates
    TX......somewhere?
    Quote Originally Posted by Keaten View Post
    then high perf. (ProMax etc.) is ya only choice....
  11. Likes Merc 2.5 liked this post
  12. #8
    Sep 2017
    Ashland city tn
    Yep. I think tux (tony) still has a PM divider for sale. I'm not sure if those dividers make a power difference or not , but that's all I use on my 2.5s because the coil setup looks much cleaner to me , and they have water pressure fitting in divider where fishing stuff don't
  13. Thanks Keaten thanked for this post
  14. #9
    Nov 2009
    Netherlands
    I just changed the exhaust divider on my 2.0 135 for a 260 one. I don't think it makes a difference in power.
    Upper one is stock, lower one is 260
  15. #10
    May 2014
    Livingston, Louisiana
    Yeah, no performance gains, like to use them for reasons 2.5 stated.
  16. #11
    Oct 2015
    Kentucky lake
    Thanks guys I like all the info...
    Aug 2019
    Palmharbor
    If you want some power gains wile it’s off do the chest work step the exhaust from Bottem of port to top of lower cylinder port just stuff all the exhaust ports with rags and get to work and have a shop vac right there with the grinder that’s a easy 50 Hp good luck!
    also the 260 plate is restrictive with the hump on exhaust flow wouldn’t use it!
  1. Merc tach question,and charging question
    By hydroguy21 in forum Electronics, Audio Systems, and Wiring
    Last Post: 07-24-2011, 04:56 AM
  2. merc 200 xri ECU question
    By jameyj103 in forum Technical Discussion
    Last Post: 04-03-2011, 09:17 PM
  3. Merc oil question?????
    By twig in forum Technical Discussion
    Last Post: 12-24-2009, 03:04 PM
  4. Merc ECU question
    By Bullet 1650 in forum Technical Discussion
    Last Post: 02-21-2005, 06:31 PM
  5. Merc hub question
    By 2us70 in forum Props, Setup, and Rigging
    Last Post: 11-15-2003, 12:57 AM
