Results 1 to 4 of 4
Thread: Opti 250xs
    Mar 2005
    Lorton,Va
    Opti 250xs
    What compression is to low for an Opti to operate? Will it perform at 95-100psi?
    Thanks
    Mar 2009
    Seymour, Tn
    The compression should be 115-130, depending on what year. The 2005XS had 130 psi and most others had 115-120. If the compression is that low, it's time for a rebuild.
    Mar 2005
    Lorton,Va
    Thanks
    David
    Dec 2013
    georgia
    I have a 2007 250xs and 2016 250 ready to go if you decide to buy
  1. Opti 200 vs 250xs vs 300xs!
    By kostas74 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-13-2013, 01:15 PM
  2. Mercury Tech: 250xs powerhead on std opti???????'s
    By aaronmt73 in forum Technical Discussion
    Last Post: 10-18-2010, 12:31 PM
  3. Dual Repower 225 opti, 225xs or 250xs/opti
    By fishnchips in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-18-2008, 08:18 PM
  4. 250xs opti vs. pro max
    By Allison's Allison in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-20-2007, 08:18 PM
  5. Which one should I get 250efi, 250xs opti,or 300x?
    By JER in forum Technical Discussion
    Last Post: 12-26-2002, 06:31 PM
