Results 1 to 15 of 15
Thread: 1992 2.5 liter = Cowl grommets
01-12-2022, 03:46 AM #1Junior Member
- Jan 2022
- Townsville Australia
HI All
Hoping if the 2 rubber lower pan cowl grommets on my 1992 2.5 EFI engine are available though a non OEM supplier. I have made a few enquiries and it sounds as genuine are non longer available. Alternatively has someone out there got a different solution for the same cowl.. images below
Thanks in advance
01-12-2022, 07:33 AM #2
Welcome to the site. Which grommets are you referring to?
RockTeam Junk
01-12-2022, 02:54 PM #3
Can u post a pic?
01-12-2022, 04:41 PM #4Junior Member
- Jan 2022
Thanks Rock, post updated with a better description an an image. Grommets are the main cowl grommets (lower section)
01-12-2022, 05:03 PM #5Junior Member
- Jan 2022
HI Merc 2.5
Thread up dated with an image. Pretty sure its the same donk as the one in your image
01-12-2022, 05:03 PM #6
Hipo cowl. Gotcha. I had few for fishing cowl good luck
MadMax1302 thanked for this post
01-12-2022, 06:31 PM #76000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
I used black rubber tubing, put a slice in the wall, go around the hole.
01-14-2022, 10:33 AM #8Scream And Fly VIP
- Jul 2013
- California
- 1,556
- 21
- 63
- 83
- 294
If you’re going to be running the rigging/vacuum tubes for the cables, hoses and wires get these.
Much cleaner set up.
https://madefi.com/shop/ols/products...olsFocus=false
Check with them for fit in the earlier cowl like you have.Last edited by Onetime; 01-14-2022 at 10:45 AM.
01-15-2022, 07:52 AM #95000 RPM
- Jun 2014
- United States
- 147
- 29
- 40
A couple of years ago I bought a set of the grommets you’re looking for from Todd Catrett at Evolution Marine. They were available at that point from Mercury.
01-16-2022, 02:17 PM #10
Nah the alien cowl grommets dot fit the euro style cowl. The alien ones are available in plastic from merc and aluminum from madEFI. As far as 260/promax euro cowls, I am not sure if the plastic part is available from mercury. I will check.
BTW, mercury calls it a "sleeve" not a grommet. That term is helpful if you are scrolling through merc parts lists.
01-17-2022, 05:55 AM #11Junior Member
- Jan 2022
Thanks for the advice much appreciated
01-17-2022, 08:21 AM #125000 RPM
- Apr 2006
- United Kingdom
- 223
- 10
- 20
- 43
In stock here.
https://www.mercruiserparts.com/8177133-grommet
If your still struggling see if you can trackdown somebody with a Formlabs 3d printer and get them to print you some in flexible resin.Last edited by techteam; 01-17-2022 at 08:26 AM.
01-17-2022, 08:23 AM #13Junior Member
- Jan 2022
That’s a great idea thanks mate
01-17-2022, 08:27 AM #145000 RPM
- Apr 2006
- United Kingdom
- 223
- 10
- 20
- 43
See edited post above
01-26-2022, 12:52 PM #155000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
I found the part numbers on Marineengine.com where they were discontinued and then took the part numbers to ebay and got them there, new in package.
Offshore cowl grommets
By lxmcbroom in forum Technical DiscussionReplies: 2Last Post: 01-08-2019, 04:20 PM -
260 cowl stainless hold down grommets
By local103racing in forum Parts WantedReplies: 0Last Post: 05-30-2016, 05:10 PM -
Rubber Grommets for Alien Cowl
By MStine06 in forum Props, Setup, and RiggingReplies: 1Last Post: 10-12-2011, 11:08 AM
