Results 1 to 6 of 6
Thread: Cougar 21 saddle tank threading
01-10-2022, 12:53 AM #1
01-10-2022, 08:57 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...any good local tank manufacturer can weld in a couple of threaded bungs into the top of your tanks for you. 3/8'' pipe thread works. of course, tank cleanliness is imperative. you doing it yourself, you can source the bungs online. there are other ways also, such as hardware installed in the fill neck hose, etc...
01-11-2022, 09:38 AM #3
The easy way is to return to the second "inlet" side of a filter/water separator.
I use the 3/8 ths NPT housing, didn't see it listed though.
https://parts.promarineusa.com/produ...l/M50/1/1/7852
01-13-2022, 01:36 PM #4Member
- Jun 2020
- Arizona
- 96
- 7
- 49
- 41
I have heard many people say DO NOT plumb it back into the water separator.
I have also heard many people say to plumb in into the water separator.
Mine is plumbed back into the tank with a 3/8.
01-14-2022, 09:20 AM #5
01-14-2022, 10:15 AM #6Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
When Mercury Hi Performance first came out with the Bosch Jetronic based fuel injection instructions said to plumb the return line to the water separator that way then later changed.
The problem with it is there’s no way to get the air out of the fuel line. Used to have to run the pump with the return line off to get the air out then hook it up to the water seperator housing. If you ran out of gas it would never prime because the air was stuck in the loop between the water separator and the engine.
Best to run the return back to the tank. When a tank didn’t have an extra threaded bung for a return fitting would install an aluminum tube splice in the rubber fill hose that had provision for the return line. Best was having the flow angled down towards the tank.
Anyone run a center fuel tank in rear of cougar mtr 21
By team supra in forum Props, Setup, and RiggingReplies: 1Last Post: 12-26-2018, 10:33 PM -
Thru-hull fittings from gas tank leaking cougar 21 MTR Help
By trickcraft in forum Fiberglass and Composites DiscussionReplies: 7Last Post: 07-26-2016, 04:49 AM -
Gss tank(s) Thru-hull fittings leaking. Cougar 21 MTR
By trickcraft in forum Technical DiscussionReplies: 6Last Post: 07-24-2016, 05:22 PM -
Cougar cub fuel tank placement????
By audio options in forum General Boating DiscussionReplies: 3Last Post: 04-22-2010, 02:16 PM -
Saddle Tank - Install
By Hamjet in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 08-21-2009, 05:56 AM
