Results 1 to 3 of 3
    May 2001
    Maine
    Cutting .250 diamond plate for Trailer side platforms
    Its 3/16 Diamond plate - can't edit subject:
    Thinking of removing the carpeted trailer side platforms and replacing with 3/16" diamond plate. What is the best way to cut the plate so as to end up with a smooth edge? I suppose if the edge wasn't smooth, I could trim the edges with 3/16" TrimLoc edging material? My side platforms are 8' x 1' and have a curve towards the bow after about 4'-5' of straight run. I have a fairly heavy-duty jig saw but not sure if it will take a 4' radius cut.
    Pekin, IL
    I will assume aluminum. Use a table saw or circular saw with carbide blade. I have cut aluminum with standard woodworking equipment for years. Have to use carbide. They do make non-ferrous blades but for the most part they are seriously pricey and I honestly see very little difference. Aluminum will not hurt your carbide tipped woodworking blades. A jig saw will cut it for about 15 seconds then you will be trying to get the aluminum out of the blade. Good luck be careful.
    Rock
    Team Junk
  3. Likes rgsauger liked this post
    Gravenhurst, Ontario.
    I used the same material for the entire deck of my trailer as well as the step pads.
    Cut with a saw as mentioned above then I dressed all the cut edges with a file.
    Took a bit of time but finished very nicely with no rough edges……as a side note, any edges that the boat may contact as it’s being loaded we’re framed with carpeted 1” bunk material. If the hull ever touches it there’s no issues.
  5. Likes rgsauger liked this post
  1. Diamond plate and tuner
    By Loef in forum Misc. Parts and Accessories
    Last Post: 03-02-2017, 10:29 PM
  2. Cutting the tongue off my trailer...
    By Rgpracer in forum Tow Vehicles and Trailers
    Last Post: 03-20-2015, 07:02 AM
  3. diamond plate
    By BRB in forum Detailing and Care
    Last Post: 03-28-2013, 07:14 PM
