Results 121 to 135 of 281
Thread: 1983 Vking rebuild
01-30-2022, 04:20 PM #121
02-01-2022, 09:03 AM #122
02-01-2022, 09:59 AM #123
I would think some very thin wood or even cardboard can make the structure and then just glass over it. I would remove them and replace with a stringer but it is a PITA to do I hear. Also, start keeping all your cottage cheese containers, sour cream containers, anything plastic that you can mix resin in. I have bags full of them so I don't need to reuse the containers that are all messy from using during layup.
1973 Viper - sold
1978 Viking - sold
1995 XB02
VkingMike liked this post
02-01-2022, 03:32 PM #124
02-01-2022, 04:04 PM #125
rjdubiel liked this post
02-06-2022, 04:17 PM #126
02-13-2022, 07:54 AM #127
02-13-2022, 09:03 AM #128
[QUOTE=VkingMike;3330748]Everything happens fairly quickly once I started mixing resinQUOTE]
Ain’t that the truth. You know your hopping when your drenched in sweat after a layup sessionHydrostream dreamin
02-13-2022, 11:07 AM #129
02-16-2022, 09:30 AM #130
Final layers of 1708 over the Coose transom, Stringers, pad core material are in. Also closed in where I cut the foam boxes back with 2 pieces of 1708. This was an intense part of glassing, as there were a lot of things that had to happen and be put into place at once. Luckily I've had some experienced help with most of the lays so far. Without that, this process would be a lot slower.
I also have all of the core material precut and ready, so thats up next. Work up the bow, then back down with the final layer of glass. I pulled the boat out this morning to let it bake in the sun all day to really get hard.
02-16-2022, 04:37 PM #131
02-16-2022, 05:28 PM #132
I spent a lot of time reading and thinking about what to do with the transom coosa bolt issue. In the end I have 3/8” glass on either side of the coosa. I am not going to use sleeves I am using 1/2” stainless rod that I am cutting to fit and threading the ends fine thread myself along with brass nylocs. Going to torque 20-30 ftlbs. I have a sheet of 1/2 aluminum I am going to cut plates or big washers out of as well. I’ll be using 4200 on the bolts as well as resin coating the inside of the holes. I think that’s it but I may change my plan a bit because I’m not there yet. I did bolt the transom eyes through to flip the hull and wow, strong. Not really worried at this point
02-17-2022, 11:01 AM #133Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Just add glass where the bolts come thru. 3/8'' is all you need to prevent crush. Skip the alum plate and just use some SS fender washers. Mine is exactly this way and no problems after many, many, years of abuse. Torque to an even amount. 25-30 is good. Just check torque after 20 hrs of operation to give some confirmation of no change.
02-19-2022, 03:28 PM #134
With the size of the knees I did for added strength, I've been kicking around the idea of fuel tanks on either side of the floor under the splashwell delete. Something like 12 gallon on both sides. Rather than a valve or having to manually switch it, I was going to do a 1" transfer tube from tank to tank at the very back / bottom. I don't really see any issue as the transfer tube will keep both tanks at the same level. Single pickup on one of the tanks. Any thoughts or suggestion are always welcome.
02-19-2022, 03:52 PM #135Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
You could do dual tanks. It just complicates things. Need 2 fills and 2 vents. Would need a valve on each tank in case the hose was to fail. Always overdo safety with fuel. Also when filling with fuel it would help to stop the flow between the two. Esp. if you add oil then gas up.
1978 vking rebuild
By rjdubiel in forum Fiberglass and Composites DiscussionReplies: 155Last Post: 04-30-2021, 01:35 PM -
1986 Hydrostream Venus 1983 Mercury 2.4 200 horsepower Trim Rebuild
By reel patriot in forum General Boating DiscussionReplies: 10Last Post: 12-31-2018, 05:55 AM -
1983 21 Sanger "classic" OB with Merc 225 engine and stringer transom rebuild/Resto.
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 09-02-2013, 10:41 PM -
1983 Hydrostream Vking Resto - core, transom, floor
By WIPolaris in forum Fiberglass and Composites DiscussionReplies: 22Last Post: 01-20-2013, 09:46 PM -
motor rebuild omc v4 1983
By MIKE OSBORNE in forum Technical DiscussionReplies: 1Last Post: 08-22-2004, 08:32 PM
