Page 17 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 241 to 255 of 281
  1. #241
    Nov 2021
    N. Idaho
    I have 2 lowers with bob's cones, one they did, one I did, no problems so far.
    I do have a old preload case that has a land and sea, or something to that effect. Who ever installed it, used bondo, and it likes to crack on the seam. Also broke a couple of drive shafts on that one.
  2. #242
    Jun 2018
    Floating around
    On a good note, mid 80’s out of a 150 is insane man. I couldnt crack 80 with a 2.5 200efi on mine so your speed is impressive as heck imo. Congrats
  3. Likes OnPad liked this post
  4. #243
    Aug 2021
    Osteen/Deltona, FL
    My assumption is the boat is quite a bit lighter after the coring. I'm sure the few mods to the 150 helped this too. The larger bore 200 carbs and going up a few main jet sizes really woke this thing up on the top end along with removing the super long exhaust tuner and replacing it for a shorty.
    83 Vking 150 Mariner 2.5L
  5. Likes LakeFever liked this post
  6. #244
    Nov 2021
    N. Idaho
    I'm impressed!!!
    What gear ratio are you running?
    I have a 150 supermag on my ltv that I did a tuner, and opened the adapter plate up a little. Can't say I've ever hit 7k rpm, even with a 26p Yamaha drag. Actually I probably did when I snapped a driveshaft.
    A little bit of alcohol, or acetone works good to smooth the surface of that PC-7.
  7. #245
    Aug 2021
    Osteen/Deltona, FL
    Honestly not sure of the lower ratio lol
    But we are back in business..
  8. Likes OnPad, LakeFever, tnelsmn liked this post
  9. #246
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by VkingMike View Post
    Mark the prop with a marker on the very top in the center, then turn the flywheel one turn. Look where the mark turned to and whala you will see 2:1 or 1.87:1.
    if the lower is a 2:1 the mark will be 180 degrees turned, or it will go from the top to the bottom of the prop. If 1.87:1 it will be a little further around and past the 180 degree mark (straight down by the skeg like a 2:1 would be).
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  10. Thanks VkingMike thanked for this post
  11. #247
    Aug 2021
    Osteen/Deltona, FL
    This is why I love this site, there is so much to learn. Thank you
  12. Likes rjdubiel, LakeFever liked this post
  13. #248
    Aug 2021
    Osteen/Deltona, FL
    I found a 40amp flexplate style flywheel, so I am going that route to avoid changing electronics to 16amp. I just cleaned it up, fresh paint and some new hardware. I've read they don't cool as well at higher RPM with less vents, but I do not do much sustained high rpm.
    Real world weighing on 2 separate scales showed the same results. It's not a lot, but every little bit can help keep load off the upper bearing.
    Cast Iron flywheel 12.6 lbs
    Flexplate flywheel 10.4 lbs
  14. Likes LakeFever liked this post
  15. #249
    Mar 2004
    Brooklyn Park, MN
    get a run going and keep it short, see how much you can get out of it. I think the issue with the 40 amp is people running miles and miles at 7K+. Just a 45 second run up to 8K I would guess is fine. if you spin that 28P to 8K you are at 95-100.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. Likes VkingMike liked this post
  17. #250
    Mar 2004
    Brooklyn Park, MN
    Can I send you my flywheels as they both need a cleanup! haha. Looks great!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  18. Thanks VkingMike thanked for this post
  19. #251
    Aug 2021
    Osteen/Deltona, FL
    Just got a GoPro a few weeks back and still learning how to use it.
    Took some video last weekend out on the river.
    https://youtu.be/C2eXZpejvTM
  20. Likes LakeFever, OnPad, Hippie459MN liked this post
  21. #252
    Jun 2018
    Floating around
    Where did you find the flywheel?
  22. #253
    Aug 2021
    Osteen/Deltona, FL
    I found this one locally from a guy.
    I struggled to find a 40amp online that would fit the right years.
  23. Thanks LakeFever thanked for this post
  24. #254
    Minneapolis MN
    What GoPro do you have? If its a 5 black or newer you'll be able to overlay the speedometer on the video etc.
    If you have a new enough one make sure the GPS is tuned on on the camera. Then download the free GoPro Quick software from them and you can add the speeds and whatnot with the software.
  25. Thanks VkingMike thanked for this post
  26. #255
    Aug 2021
    Osteen/Deltona, FL
    So why is it a good idea the verify timing after replacing a flywheel?
    Removed the cast iron unit and got the flexpate style flywheel installed on Saturday. I purchased one of Jay's dial indicators and started on cylinder #1. I was surprised when 0 was dead on with the TDC pointer. I indexed all 6 cylinders and made marks for TDC and 25 degrees BTDC on each. I then connected my light and went for timing. I was previously about 22-23 degrees full advance, new flywheel had me at 17 degrees full advance and base in the negative numbers when idling. I set it to 23 again and checked all cylinders. All of them fell right at 22-23 except for Cyl #6 at 25 degrees.
  27. Likes rjdubiel, LakeFever, OnPad liked this post
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. 1986 Hydrostream Venus 1983 Mercury 2.4 200 horsepower Trim Rebuild
    By reel patriot in forum General Boating Discussion
    Last Post: 12-31-2018, 05:55 AM
  3. Replies: 2
    Last Post: 09-02-2013, 10:41 PM
  4. 1983 Hydrostream Vking Resto - core, transom, floor
    By WIPolaris in forum Fiberglass and Composites Discussion
    Last Post: 01-20-2013, 09:46 PM
  5. motor rebuild omc v4 1983
    By MIKE OSBORNE in forum Technical Discussion
    Last Post: 08-22-2004, 08:32 PM
