Results 211 to 225 of 281
Thread: 1983 Vking rebuild
06-09-2022, 04:32 PM #211
I run +2 1/4 on my LTV and Bullet, but have to run 4 blades, with a full 14 1/2 diameter.
06-22-2022, 09:00 AM #212Member
- Aug 2020
- Dallas
- 58
- 22
- 11
Well whatcha been doing the last couple weeks?
06-22-2022, 09:24 AM #213
06-22-2022, 09:26 AM #214Member
- Aug 2020
- Dallas
- 58
- 22
- 11
If you don't mind me asking, where did you send your lower to be coned? What is the approximate cost without straightening the propshaft? I think that's the next step on mine.
06-22-2022, 09:58 AM #215
06-22-2022, 12:41 PM #216Member
- Aug 2020
- Dallas
- 58
- 22
- 11
That’s not too bad for parts and labor. I’m in Texas so shipping would be very expensive…
06-22-2022, 01:40 PM #217
06-30-2022, 11:17 AM #218
07-07-2022, 10:47 AM #219
LakeFever liked this post
07-08-2022, 11:06 AM #220
07-08-2022, 01:31 PM #221
put it higher if you have time now and lower the jackplate so you dont have to unbolt the motor tomorrow! Propshaft center line even with the bottom of the pad is the lowest you will go, likely higher.
1973 Viper - sold
1978 Viking - sold
1995 XB02
OnPad liked this post
07-14-2022, 11:42 PM #222
RJ is right. Hang the motor higher and drop your plate. Going for top speed you won't be below prop shaft CL even with pad. I'm running 7/8" above. 28 big ear should run pretty dang good. I like a chopper on my hull as well, but an ET still runs better for me.
VkingMike thanked for this post
07-15-2022, 06:21 AM #223
Tony where do you run your engine height for take off/skiing?
07-15-2022, 08:54 AM #224'78 Hydrostream Viking/'98 225 ProMax
07-19-2022, 10:43 AM #225
Moved the engine all the way up and now the prop shaft centerline is 1/4 above the pad. The boat handles and performs so much better than I could have even imagined. All of the previous issues with propeller torque leaning the boat are gone and it flies center on the pad. Even a lot of the chine walk has clamed down. No top speed runs yet, it was bad weather on my first test run and the sprinkling rain hurts at speed lol
1978 vking rebuild
By rjdubiel in forum Fiberglass and Composites DiscussionReplies: 155Last Post: 04-30-2021, 01:35 PM -
1986 Hydrostream Venus 1983 Mercury 2.4 200 horsepower Trim Rebuild
By reel patriot in forum General Boating DiscussionReplies: 10Last Post: 12-31-2018, 05:55 AM -
1983 21 Sanger "classic" OB with Merc 225 engine and stringer transom rebuild/Resto.
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 09-02-2013, 10:41 PM -
1983 Hydrostream Vking Resto - core, transom, floor
By WIPolaris in forum Fiberglass and Composites DiscussionReplies: 22Last Post: 01-20-2013, 09:46 PM -
motor rebuild omc v4 1983
By MIKE OSBORNE in forum Technical DiscussionReplies: 1Last Post: 08-22-2004, 08:32 PM
