Page 13 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 181 to 195 of 281
  1. #181
    Aug 2021
    Osteen/Deltona, FL
    Quote Originally Posted by Jim Speros View Post
    Great Thread. You have been getting after it at a marching pace. Nice work. I find it motivating. Thank you. Won't be long and I'll be taking my old girl apart.
    Cheers
    Thank you, when I set my mind to something I get hyper focused and even obsess a little lol.. excited to get it back in the water
    83 Vking 150 Mariner 2.5L
  2. #182
    Aug 2021
    Osteen/Deltona, FL
    A little more completed this morning before I went into work. This way I can sand when I get home. Some fairing layed down to smooth out over the rough 1708 cloth and some of the areas on the transom and over the patches from some old trims tabs from who knows how long ago.
ID:	503275Click image for larger version.
  3. Likes LakeFever, rjdubiel, tnelsmn liked this post
  4. #183
    Aug 2021
    Osteen/Deltona, FL
    Measure 40 times and measure again. Then drilled holes with a homemade fixture to ensure the are square with the transom. I am pleased with the results. Also painted the splash-well delete and transom prior.
ID:	503598Click image for larger version.
  5. Likes 89LASER, LakeFever, tnelsmn liked this post
  6. #184
    Aug 2021
    Osteen/Deltona, FL
    And although I know not necessary, instead of washers I made some 3/16 plates for the inside. I've search a lot and seen a lot of recommends for bolt torque, but just want to verify the information still holds true as a lot are older threads. The transom is two 3/4 pieces of Coosa and 1708, total thickness is 2", so 35-40ft lbs does that sounds right?
  7. Likes LakeFever liked this post
  8. #185
    Minneapolis MN
    Sounds about right. I went 50ft/lbs, I have a plywood transom.
  9. Thanks VkingMike thanked for this post
  10. #186
    Aug 2021
    Osteen/Deltona, FL
    I went 40ft lbs and it seemed to work perfectly. I also hung the mid section and got the seastar bolted back on. Started on re-wiring last night and got all the gauges and trim switch ran. Mounted the hot foot and bolted the steering wheel back on. Just making my way towards the back while I wait on my base gasket for the powerhead.
ID:	503680Click image for larger version.
  11. #187
    Aug 2021
    Osteen/Deltona, FL
    Just trucking along with all the little final details. Got the powerhead bolted back on and lower cowl in place. Stared mocking up fuel tank, wiring, throttle and shift cables, rigging tubes. I'm finding each time I get rolling I need another little part that holds me up lol.
ID:	503924Click image for larger version.
ID:	503925Click image for larger version.
  12. Likes rjdubiel, LakeFever, tnelsmn, 89LASER liked this post
  13. #188
    Jun 2018
    Floating around
    Nice clean job all round there. I hear ya on the parts thing, it’s really a huge challenge during a build to have what you need on hand the moment you need it. Even the pro shops suffer from parts and material struggles and that’s not meaning COVID back orders either
  14. Thanks VkingMike thanked for this post
    Likes VkingMike liked this post
  15. #189
    Aug 2021
    Osteen/Deltona, FL
    Little by little, it's coming together. The vinyl showed up, so I made the stripes and center strip on the splashwell delete to match the front pattern. Got the rigging hoses, cables, wires, and everything ran to the motor. Working on battery and fuel tank mounting this week. Looking to fire it up and if all goes as planned a water test next weekend.
ID:	504103Click image for larger version.
ID:	504104Click image for larger version.
  16. Likes LakeFever, 89LASER, tnelsmn, d00m, MrBoatYard liked this post
  17. #190
    Minneapolis MN
    Is there some sort of check valve set up on the breather filter? I would be concerned about fuel spilling out of that. Even with a line mounted up to breather in the splash well I still get some spillage.
  18. #191
    Aug 2021
    Osteen/Deltona, FL
    Quote Originally Posted by tnelsmn View Post
    The breather fitting does have a one way valve in it, but I may extend it up further just incase
  19. Likes tnelsmn liked this post
  20. #192
    Aug 2021
    Osteen/Deltona, FL
    Fuel tank went in last night along with the new battery tray. Filled up with fresh fuel and fired it up. I'm just left with bleeding the steering and check over all my bolts. From there its ready for a water test. First fire up video attached.
    https://youtube.com/shorts/XNFQJ6hbmKI
  21. #193
    Aug 2021
    Osteen/Deltona, FL
    Another quick video from last nights fire up. Everything seems to doing well, I'm excited to get back in the water.
    https://youtube.com/shorts/FKV6-iFWJkQ
  22. Likes rjdubiel, LakeFever liked this post
  23. #194
    Should pop right on plane with the weight foreword like it is. Might be able to use a little positive trim too. Looking real nice
  24. Likes VkingMike liked this post
  25. #195
    Aug 2021
    Osteen/Deltona, FL
    Took the boat out this weekend for the first time since re-core.
    Everything went well, just going to have to learn how to drive it all over again. It gets on plane ridiculously easy, and almost all of the porpoising is gone. I did run into some running issues near the end of the day and found the needle seat had backed out on the lower carb, but was able to limp the boat back in. I am still running a stock lower unit for now, so the motor is a bit low which seems to causes the boat to lean left under power, until getting on above a certain mph and trim. Is that common on these? Snapped a few pics and attached them.
ID:	505189Click image for larger version.
ID:	505190Click image for larger version.
  26. Likes rjdubiel, 89LASER, tnelsmn, MrBoatYard liked this post
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. 1986 Hydrostream Venus 1983 Mercury 2.4 200 horsepower Trim Rebuild
    By reel patriot in forum General Boating Discussion
    Last Post: 12-31-2018, 05:55 AM
  3. Replies: 2
    Last Post: 09-02-2013, 10:41 PM
  4. 1983 Hydrostream Vking Resto - core, transom, floor
    By WIPolaris in forum Fiberglass and Composites Discussion
    Last Post: 01-20-2013, 09:46 PM
  5. motor rebuild omc v4 1983
    By MIKE OSBORNE in forum Technical Discussion
    Last Post: 08-22-2004, 08:32 PM
