Results 166 to 180 of 281
Thread: 1983 Vking rebuild
03-27-2022, 01:58 PM #166
Looks really good! Your almost done
VkingMike thanked for this post
03-30-2022, 07:48 AM #167
Ok guys, question.
I have the old holes still visible from where the jackplate was mounted beforehand, but what is the best way to center and make sure everything is square to drill the new holes or at least verify the old ones are good? I ask because I have found that nothing inside or outside of these boats is symmetrical. Hell measuring for the center steer had me scratching my head because everything side to side wasn't the same lol.
03-30-2022, 07:55 AM #168Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7149
- 3 Post(s)
You want to center everything on the transom from the pad. I am fortunate to have Porta Products in my back yard so I use one of their transom jigs to clamp on and drill square. That is what you need "transom jig" with drill guides so your holes are square through the transom and backer plates all line up. You are close, tell Scott I told you to call-he will treat you right.
03-30-2022, 09:29 AM #169
LakeFever liked this post
03-30-2022, 02:56 PM #170Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Laser level......
03-30-2022, 05:52 PM #171
I’m with xstream. I’m using a cross line laser off the center of my pad and drilling transom holes level to the laser on center. Height wise I don’t know yet but high as safely possible.
The drill fixture is badass if you can get one. I might fab up something for thisHydrostream dreamin
03-31-2022, 07:16 AM #172
I did some measuring last night and the old holes in the outer glass seem to be spot on with actual center. If all checks out, I'll just need to borrow a jig for drilling, which I have access to.
If you guy have any examples of using a laser level, I would love to see. I guess I'm having trouble picturing how to go about it.
03-31-2022, 07:45 AM #173
If you want to verify center you need a cross line self levelling laser level. Referencing all off the pad only to sit the boat level for and aft and side to side. Meaning the pad is perfectly level on front back and side to side. Then at the rear near the drain plug so you can see it from the back, measure and mark center of the pad with a pencil, not a marker you want a fine accurate center line. Measure five times lol.
Measure the center of the transom both vertical and horizontal and make a small mark in the center. Move the level to the rear of the boat and broadcast the cross line parallel to the bottom of the pad which you know to be true level as well as the vertical beam on your center mark of transom and that will give you true center up the transom square to the pad and it’s center. Simply copy that over tape and pencil, Mark your height and drill square to that center line. Then your motor will be perfectly centered and square to the pad. Hope this makes senseHydrostream dreamin
03-31-2022, 08:07 AM #174
Ahhh ok. That did help, thank you. I'll be testing this after work today.
Here is what I did last night, 3 layers of overlapping1708 to cover the splashwell. Then did the torn CSM at the end on the transom itself. I originally planned to go down the transom further, but was told it really isn't all that necessary. As of right now, that is the last of the glass work for this boat! (other than the spots you can see on the transom I'll fill) I wanted to try and keep the original lines that flow into the splashwell and I'm happy with how it came out. Just a bit of fairing to do over this to smooth it out and then paint.
03-31-2022, 08:50 AM #175
Really clean work! Nice cat eye with race stars there too
VkingMike liked this post
03-31-2022, 09:39 AM #176
I did only one layer of 1708 or was it 1808, either way I only did one over the delete and only went 1 inch down the outside of the transom. Then one layer inside where the delete and transom meet, a 4 inch wide strip is all I did to tie it all together. You are bulletproof with this build!
1973 Viper - sold
1978 Viking - sold
1995 XB02
03-31-2022, 10:04 AM #177
04-01-2022, 07:27 AM #178
I tackled the bow eye replacement last night, which with the cap on is just silly in all honesty. The bolts were seized, so I had to cut it from the outside, then try and push the pieces inwards. Top contacted the nose cap, so I had to crawl in with an air saw and ear plugs. The amount of load cursing that echoed from inside the bow of my Vking last night was probably heard for blocks, so good thing I'm in the woods.
The good news is, the wood is in excellent shape and I was actually surprised at how thick the hull is up there. I made an aluminum backing plate for my piece of mind anyways.
04-01-2022, 08:34 PM #179
Great Thread. You have been getting after it at a marching pace. Nice work. I find it motivating. Thank you. Won't be long and I'll be taking my old girl apart.
CheersJim
04-02-2022, 05:46 AM #180
I wanted to revisit this post so that others may find it easier. These two tools right here have been the most valuable in this rebuild. The 1/2 sander has been used in almost every part of the build specifically. Do not hesitate on picking this up if you are planning any boat restoration.
1978 vking rebuild
By rjdubiel in forum Fiberglass and Composites DiscussionReplies: 155Last Post: 04-30-2021, 01:35 PM -
1986 Hydrostream Venus 1983 Mercury 2.4 200 horsepower Trim Rebuild
By reel patriot in forum General Boating DiscussionReplies: 10Last Post: 12-31-2018, 05:55 AM -
1983 21 Sanger "classic" OB with Merc 225 engine and stringer transom rebuild/Resto.
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 09-02-2013, 10:41 PM -
1983 Hydrostream Vking Resto - core, transom, floor
By WIPolaris in forum Fiberglass and Composites DiscussionReplies: 22Last Post: 01-20-2013, 09:46 PM -
motor rebuild omc v4 1983
By MIKE OSBORNE in forum Technical DiscussionReplies: 1Last Post: 08-22-2004, 08:32 PM
