Results 1 to 13 of 13
    Apr 2014
    miami
    Evinrude 90 questions
    I purchased a Checkmate that came with a Evinrude 90 that the prior owner says runs and that he rebuilt it with all kinds of high performance parts.
    I'm not interested in the engine as a new one is on the way.
    Is this something of interest or just junk?
    Here is what he told me he did to the engine.
    That engine has been bored out 30 over . And re sleeved. It has forged Wiseco racing Pistons. The block has been ported 4 high flow. The heads are milled for high-compression. Polished and balanced racing crank. Exhaust tube has been shortened and opened up. The lower unit has been drilled out to let the exhaust out before it goes through the prop. For higher acceleration at lower speeds. Bigger carburetors with bigger Jets. Advanced timing. The engine runs just fine on 90 tes pump gas. It does have more power if you use 115 leaded racing gas. But it's not necessary
    Oct 2010
    Harrisburg,Pa
    A couple things wrong with his statement. although you can re-sleeve a crossflow, why would you to just bore .030 over? You can not mill stock heads enough to get hi compression. You need different year heads. Would love to know where he got a polished, balanced, racing crank, lol Advanced timing that would be the wrong way to go. And if motor ran fine on 90 pump gas, 115 race fuel will not help, in fact it may hurt performance,
    Why anyone would do all that to a 90 when you could sell it and get a 140 crossflow, same block size, for next to nothing now days is beyond me.
  3. Thanks KIRCHNER thanked for this post
    It must be true, 1st post in how many years....
  5. Likes Forkin' Crazy liked this post
    Quote Originally Posted by perfmarine1 View Post
    How many years did they build the 90hp v4 looper
    Aug 2009
    mpls,mn
    Must be one of those ficht hi-perf racing motas.
    Oct 2010
    Harrisburg,Pa
    True that could be a looper, he did not say, even though would still go 140 hp.
    Aug 2009
    mpls,mn
    Like this mod 140 13 inch i just built.
    Attached Thumbnails Attached Thumbnails stacker done 12-1-21 005.jpg   stacker done 12-1-21 018.jpg
  10. Likes VkingMike, 89LASER, sharpeye Mike, loop liked this post
    It has my curiosity if cut, hogged out, which pistons and sleeves, might be worth keeping?
    Quote Originally Posted by racervboat View Post
    Remember seeing drawings the R&D did with a twin tuner setup, each 180° pair side had its own tuner in the leg, the chest still common to also have port to port signal.
    The great corn desert of Iowa
    What, pray tell, is that little beast going on?
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
  14. #11
    Aug 2009
    mpls,mn
    Quote Originally Posted by Turtleherder View Post
    13 ft checkmate or a viper? It's only going 800ft at a time.
  15. Likes 89LASER, loop liked this post
  16. #12
    Aug 2009
    mpls,mn
    Sorry should probably let the poster have his thread back.
    that'll take years more.....
    But some pics would be good
  1. EVINRUDE E-TEC Questions
    By 2.5-21 in forum Technical Discussion
    Last Post: 11-09-2018, 09:07 AM
  2. 2002 Evinrude 250 Questions
    By Greg G in forum Technical Discussion
    Last Post: 12-04-2009, 09:08 AM
  3. Evinrude 115 V4 questions
    By Rastafari in forum Technical Discussion
    Last Post: 06-15-2009, 10:53 PM
  4. evinrude V8 questions
    By Reaction19 in forum Technical Discussion
    Last Post: 08-07-2007, 06:23 PM
  5. 95 Evinrude 130 questions
    By Mach2 in forum Technical Discussion
    Last Post: 05-30-2006, 09:49 PM
