Results 1 to 11 of 11
    Feb 2019
    Midwest
    225 promax injector OEM Keihin part number?
    I'm looking to get a set of 225 promax injectors but I don't want to buy them from Mercury for $500 a piece. I was wondering what Honda cars/engines share the same injector as the promax? Also, what CC is the stock orange tip Keihin injectors? I haven't been able to find a thread on here that addresses my question since most threads talk about how the 280 shares the same injectors as the 1980s Mercedes SL.
    Jan 2003
    aalsmeer
    Ebay!
    Feb 2019
    Midwest
    Quote Originally Posted by PanRonnie View Post
    Ebay!
    I saw that earlier. If I can't find a new set, I may go that route.
    Nov 2019
    Canada
    Buy used and have them cleaned/serviced. I'm not sure if those are used in any other application but I kind of doubt it. KeiHin does not use part numbers like most of the other manufactures. As far as I know they only sell to OEMs who sell them under the OEM part number. They are literally just called "Pink Tips"
    Whats wrong with yours that you need another set?
    Blake
    www.InjectorService.com
    Call/Text - 204-326-0390
    Feb 2019
    Midwest
    Quote Originally Posted by InjectorService View Post
    Blake
    I bought a used engine that recently had the injectors cleaned and it said that 3 of the 6 are weak. I would like to keep using them if I could but at the same time I don't want to put money into something that needs replacing. Could I text you a pic of the sheet I have and get your thoughts on my situation?
    Jan 2020
    Pinole, Ca
    Yeah just referred to as pink tips. I got some used ones that could fill in your set of "weak" ones if Blake doesn't have some at his place. I also have a complete set of flow matched ones, but if you already have 3 good then there's no sense in buyin 6...
    Jul 2002
    FT WORTH, TEXAS
    i have cleaned and sold 100's of these in sets for years they work or they dont most generally i do know of some shops who sell BS as well as cleaning service , ive recleaned and checked several sets that were supposed to have been "something wrong" and found nothing i returned all of them to the customers no charge except shipping just know who you use for service my .02
  8. Likes tux974, rgsauger liked this post
  9. #8
    I'm with you Bobby!
    Simpson, I say forget the sheet and send them to Injectorservice to check for you.
    Yes, they are known as "Pink tips" also come and work on all 300X engines so that should tell you how much fuel you can run through them.
  10. #9
    Feb 2019
    Midwest
    Quote Originally Posted by tux974 View Post
    I'm with you Bobby!
    Yes, they are know as "Pink tips" also come and work on all 300X engines so that should tell you how much fuel you can run through them.
    Another quick question. Why do some look orange. I have mine apart and the tips look orange. Does this happen with age or something?
  11. #10
    Quote Originally Posted by simpson_3 View Post
    Yes, age and fuel.
  12. #11
    Aug 2005
    West Allis,Wisconsin
    Would u consider selling the flow matched set 25two. stroke?
  1. Mercury Tech: Injector spring clip part number
    By Sutphil in forum Technical Discussion
    Last Post: 08-05-2021, 09:29 PM
  2. Whats the part number i need for a switchbox for my 96 225 promax ?
    By ndependent in forum Technical Discussion
    Last Post: 08-07-2017, 05:37 PM
  3. Fuel injector part number Mercury 280 ROS Outboard
    By catfish123 in forum Technical Discussion
    Last Post: 03-19-2017, 05:23 PM
  4. Fuel Injector Part Number
    By PhastBoat in forum Technical Discussion
    Last Post: 06-10-2003, 09:11 PM
