Results 1 to 12 of 12
    Nov 2021
    Holland,Michigan
    Where to order parts
    Where does everyone order there parts from?
    1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
    With a need for speed!!
    Jun 2018
    Floating around
    Depends what your after. Promarine is a good spot for go fast engine parts
    Nov 2021
    Holland,Michigan
    Im working on a 1988 150 blackmax and having difficulty finding some gaskets.
    Thanks, i will give that a try.
    Nov 2021
    Holland,Michigan
    The link for there engine parts is not working, just my luck.
    Jun 2018
    Floating around
    Call them during business hours. I’m sure they will have the gaskets you need
  6. Thanks SJD1974 thanked for this post
    charlotte,nc
    go here. it tells you everything you need to know, even aftermarket part numbers
    http://www.marineengine.com/parts/me...0d5fb4b4cf9da2
    death is certain; life is not
  8. Thanks SJD1974 thanked for this post
    Don't be surprised if you find that no one answers the phone or fills / ships online orders until after the first of the year. Standard practice, as is all of them going off of the new 2022 price sheets ...
  10. Likes LakeFever liked this post
    Aug 2015
    Southeast
    I buy a lot of parts from Jacos in TN. Helpful if you look up your part numbers first on Mercs site or at least have your serial number.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
  12. Thanks SJD1974 thanked for this post
  13. #9
    Nov 2021
    Holland,Michigan
    I'll bet bleed lines are going to be fun to find they don't look so good on my motor
    Pekin, IL
    Pro Marine sells the hose by the roll.
    Rock
    Team Junk
  15. Thanks SJD1974 thanked for this post
  16. #11
    Apr 2017
    Holland,MI
    Quote Originally Posted by SJD1974 View Post
    I'm a dealer for WSM and can help you out with the gaskets. I also have a roll of the bleeder line. Let me know if your interested.
  17. Thanks SJD1974 thanked for this post
    Likes SJD1974 liked this post
  18. #12
    Nov 2021
    Holland,Michigan
    I have all the gaskets now and found and ordered the bleeder line from Wholesale Marine.
    Thanks for the help though.
    I may call on you though when I go to put them bleeder lines on and may not believe if I got one in the right place or if I may have some other silly thing out of place with the wiring. I took notes on where everything goes but there can be those times where it just don't look right.
  19. Likes ShadowFlier liked this post
  1. Mercury Tech: Reassembling "MIDSECTION" Parts of 1981 Mercury 225 - Order of Operations Question
    By 97mirage in forum Technical Discussion
    Last Post: 04-01-2012, 08:20 PM
  2. OMC Tech: Where I can buy-order Johnson's V8 Spare Parts there in USA?
    By Jennifer in forum Technical Discussion
    Last Post: 10-24-2011, 04:45 PM
  3. Plan ahead if you think you need to order any Mercury parts
    Last Post: 03-31-2007, 12:23 PM
  4. Thanks.ill order one of those,
    By stroker in forum Technical Discussion
    Last Post: 02-26-2002, 11:34 PM
