Results 1 to 3 of 3
Thread: Merc 2.5 crank oil gear
12-27-2021, 02:04 PM #1Member
- Mar 2016
- N/A
- 63
- 7
Hi,
Happy Christmas. I have a 2.5 Merc in bits that’s had the oil injection removed including the plastic worm gear from The crank. Would it be ok to reassemble the powerhead without this or are they balanced from the factory with it?
12-27-2021, 05:08 PM #2
It will be fine. Little bit of stuffing loss.
RockTeam Junk
12-27-2021, 09:07 PM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...if the gear is still good, leave it on the crank. then you wont have any loss, & someone has the option of utilizing it in the future. no performance loss of leaving it in place. use the correct oring plug/block-off plate for the hole...
2.5 Crank / Oiler Gear Loose
By cmb1998 in forum Technical DiscussionReplies: 4Last Post: 12-07-2017, 10:55 AM -
CRANK With Oil Gear.
By Mrzip in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-23-2017, 05:44 PM -
I want my Inline Merc to crank in gear???
By coreyh912 in forum Technical DiscussionReplies: 9Last Post: 09-14-2009, 09:02 PM -
oil gear on crank
By RSM in forum Technical DiscussionReplies: 7Last Post: 02-05-2003, 08:06 PM
