Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 88
  1. #31
    Looks good. Who supplied the coosa?
  2. #32
    Oct 2021
    Ontario Canada
    Got the cossa/pvc foam from Noah’s marine: http://www.noahsmarine.com/c.html
  3. Thanks FMP thanked for this post
  4. #33
    Thanks
  5. Likes Zammit_Racing liked this post
  6. #34
    Oct 2021
    Ontario Canada
    So I was thinking of adding more core to the bottom of the boat so I bought a sheet of divinycell foam it’s about 3/16” of a inch thick. Glued down with CSM edges filled in with thickened resin and 1 layer of 1708 over all the core 2 layers on the pad, not the prettiest job was in a bit of a rush to get it done but in not to worried about it, it will never be seen.
    video: https://youtu.be/EeEEmhoRNAM
ID:	500004Click image for larger version.
ID:	500005Click image for larger version.
ID:	500011Click image for larger version.
ID:	500006Click image for larger version.
ID:	500007Click image for larger version.
ID:	500008Click image for larger version.
ID:	500009Click image for larger version.
  7. Likes LakeFever, VkingMike, tnelsmn, 89LASER liked this post
  8. #35
    Oct 2021
    Ontario Canada
    Here it is! Full transom/knees possibly the first hydrostream with a full transom and first voodoo with transom knees?..
    it’s extremely strong can’t move it at all and extremely light weight!
    I rate this transom for 200+hp. But would never happen as the boat is too small to float it but 100% can hold the weight and power witch is crazy on such a small boat.
    4-layers of 1708 over Cossa board 3-layers over the side wing core, knees tabbed in with 6oz cloth followed by 1708 then CSM over everything to tie in all the tabs, in told 9-layers was put into the transom.
    video: https://youtu.be/sJ-a3Wdjjn8
ID:	500421Click image for larger version.
ID:	500422Click image for larger version.
ID:	500423Click image for larger version.
ID:	500424Click image for larger version.
ID:	500425Click image for larger version.
ID:	500426Click image for larger version.
ID:	500427Click image for larger version.
ID:	500428Click image for larger version.
ID:	500429Click image for larger version.
ID:	500430Click image for larger version.
ID:	500431Click image for larger version.
ID:	500432Click image for larger version.
ID:	500433Click image for larger version.
ID:	500434Click image for larger version.
  9. #36
    Oct 2021
    Ontario Canada
    I decided to Gelcoat the core to seal it up and to fully cure the resin underneath..
    1-thick coat.
    also drilled some drain holes in the knees to the bilge box area.
    video:https://youtu.be/qu3p2TWq3Bo
ID:	501031Click image for larger version.
ID:	501032Click image for larger version.
ID:	501033Click image for larger version.
ID:	501035Click image for larger version.
ID:	501036Click image for larger version.
  10. Likes VkingMike, FMP, tnelsmn, XstreamVking, 89LASER liked this post
  11. #37
    PARADISE /Naples
    Nice!
    a Yamaha 90 two stroke is 261 lb and easy to cut down to 15" lighter yet add compression.
  12. Likes Zammit_Racing liked this post
  13. #38
    Quote Originally Posted by CUDA View Post
    Nice!
    So's a 140 side bullet pickup Chryco
  14. #39
    PARADISE /Naples
    40 + year old motor... TREX ?
  15. #40
    Oct 2021
    Ontario Canada
    Back at it. Been working 7 days a week for 4 months straight. Using my leftover 1/2” pvc coring to core the bow of the boat so it can be walked on, I always walked on it before but definitely shouldn’t of sine the fiberglass is super thin and I could of broke threw, also put my dash board in with 3/4” Cossa, and I put 1/8” foam up the side boards of the boat to give it some strength witch it does.
    1lyr of 1708 on both sides of pvc on the bow.
    CSM over dash board, and side board foam.
    video: https://youtu.be/mr_KCK3S1bE
ID:	505984Click image for larger version.
ID:	505985Click image for larger version.
ID:	505986Click image for larger version.
ID:	505987Click image for larger version.
ID:	505988Click image for larger version.
ID:	505989Click image for larger version.
ID:	505990Click image for larger version.
  16. Likes LakeFever, tnelsmn, 89LASER liked this post
  17. #41
    Doing real nice glass work will be a tuff lil boat
  18. Thanks Zammit_Racing thanked for this post
  19. #42
    ...wish everyone would catch the foam fever as you have. nice work...
  20. Thanks Zammit_Racing thanked for this post
  21. #43
    Oct 2021
    Ontario Canada
    Putting in my Cossa floor! 1708 on the underside of the floor, then Bonded it to the boat using epoxy that I thickened, then filled gaps around all edges with thickened resin, then tabbed the floor in using CSM, then I cut out full size sheets of CSM to go over the entire inside of the boat looks real good now!
    Video:https://youtu.be/xfIND0VC_f8
ID:	508309Click image for larger version.
ID:	508310Click image for larger version.
ID:	508311Click image for larger version.
ID:	508312Click image for larger version.
ID:	508313Click image for larger version.
ID:	508314Click image for larger version.
  22. #44
    Oct 2021
    Ontario Canada
    Been working like crazy on the boat lately getting so close to putting back into one pice again!
    Made a seat mount and glassed it in, got a pice of 1/4”aluminum plate drilled and taped for the foot pedal no screws going into anything on the boat, Put a strip of honeycomb at the back for the gas tank to sit on so it won’t sit on a angle, Made a floor mount shifter plate and glassed it down,
    I made fiberglass cylinders to run wires/hydraulic lines “rot prof”
    Made a mount for the Tethered cord out of 1/16” stainless plate glassed it right above where my leg will sit.
    Bought new led lights and put them in, I had put that pvc trim there when I bought the boat and had the led’s and loved them, So I had to put them in again went with just blue..
    Threw a quick coat of waxed gel on the inside where you’ll see, I will be sanding it and do some filler work to get all the imperfections fixed, Then I will be Gelcoating the whole inside of the boat.
ID:	508956Click image for larger version.
ID:	508957Click image for larger version.
ID:	508958Click image for larger version.
ID:	508959Click image for larger version.
ID:	508960Click image for larger version.
ID:	508961Click image for larger version.
ID:	508962Click image for larger version.
ID:	508963Click image for larger version.
ID:	508964Click image for larger version.
ID:	508965Click image for larger version.
ID:	508966Click image for larger version.
ID:	508967Click image for larger version.
ID:	508968Click image for larger version.
ID:	508969Click image for larger version.
ID:	508970Click image for larger version.
  23. #45
    Oct 2021
    Ontario Canada
    *FOR SALE* $200
    Hydrostream voodoo cradle.
    It has worked perfectly for me hopefully someone one could use it!
ID:	509126Click image for larger version.
ID:	509127Click image for larger version.
ID:	509128Click image for larger version.
ID:	509129Click image for larger version.
ID:	509130Click image for larger version.
  1. Hydrostream VooDoo
    By Coonass2020 in forum Hulls Wanted
    Last Post: 08-31-2021, 03:55 PM
  2. One of a kind Hydrostream Voodoo?
    By shane65 in forum Ebay Listings and Other Internet Listings
    Last Post: 05-20-2021, 08:19 AM
  3. 13' Hydrostream VooDoo
    By 89LASER in forum Ebay Listings and Other Internet Listings
    Last Post: 04-29-2020, 01:44 PM
  4. Hydrostream Voodoo
    By Voodoo in forum Technical Discussion
    Last Post: 04-19-2010, 07:15 PM
