Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 88
    Jun 2018
    Floating around
    It’s amazing how strong fiberglass is when you see how thin the skins are on these things and yet holds your motor up even with rotted transom. Your going to have a sweet little rig when it’s all done
  2. Likes VkingMike liked this post
  3. #17
    Oct 2021
    Ontario Canada
    Tell me about it it’s unbelievable! I’m building this transom to hold a 200+hp motor. But all probably never get there as the boat would be under water form the weight but will be strong enough to hold anything!
  4. #18
    Nicely worked , personally I would have still used Baltic birch or equivalent in the transom etc and balsa core as needed.
    Hope it works out perfectly for you.
  5. #19
    Oct 2021
    Ontario Canada
    Thanks. I agree but my motor is bigger than the boat and might just go bigger and better in the future so I wanna build it right. Not ever have to worry about it!
  6. #20
    You need to go back old school two stroke 15" leg and like it
    JMO
  7. Likes Zammit_Racing liked this post
  8. #21
    JMO
    Because 300+lb of 70HP ..... heck no
  9. #22
    Oct 2021
    Ontario Canada
    yea the boat can hardly float it..
  10. #23
    Jun 2018
    Floating around
    Wow!
  11. Likes Zammit_Racing liked this post
  12. #24
    Oct 2021
    Ontario Canada
    Looks like a little much it the pic^ above! It’s not actually the bad just a little exaggeration but it rides really low in the back end it’s still sits under water a bit at the dock everyone thinks it’s sinking funny because it actually does look like it!!
ID:	499234Click image for larger version.
  13. #25
    Aug 2021
    Osteen/Deltona, FL
    This is exactly what I was blown away by. They are rotted and still hold the weight and power.
    83 Vking 150 Mariner 2.5L
  14. Likes Zammit_Racing liked this post
  15. #26
    Toss that barge motor before it hurts you
  16. #27
    Minneapolis MN
    Getting right after it! Cool little boat, looking forward to seeing the progress.
  17. Likes Zammit_Racing liked this post
  18. #28
    Oct 2021
    Ontario Canada
    Got my core materials I will be doing a full composite build so it lasts forever also this will be a light weight build! Gonna build it strong and as light as possible!
    couple pics of the first core going in. More to go in later on! Not to happy with all the air bubbles. Will be grinding them down! It was my first time fiberglassing I probably should of tried on something else first but whatever that’s the way I am just go for it ahah! But it worked out it got a good bond and it’s doing it’s purpose, just a couple air bubbles need to be corrected.
    Core 1/2”PVC foam
    Cossa board 3/4”
    videos:
    Cossa composites:https://youtu.be/Vl13F4hOCGk
    PVC core:https://youtu.be/vsb9hg8kb5c
ID:	499389Click image for larger version.
ID:	499390Click image for larger version.
ID:	499391Click image for larger version.
ID:	499392Click image for larger version.
ID:	499393Click image for larger version.
ID:	499394Click image for larger version.
ID:	499395Click image for larger version.
    1 layer of 1708 over core.
  19. Likes tnelsmn, rgsauger liked this post
  20. #29
    I recall having this discussion with member Nice Pair and one if his beautiful restorations. Ply or composite in the transom. Maybe he'll chime in and give some info.
  21. Likes Zammit_Racing liked this post
  22. #30
    Oct 2021
    Ontario Canada
    Got my Cossa transom epoxied in and I also cored the side wings, I thought to doing that as I was looking how to make it real strong, So it’s basically a full transom now “worlds first full transom hydrostream” ??..
    The side wings are very thin and it would of been a bit of a pain to fiberglass the Cossa to the wings without the core there because the Cossa stuck out about 3/4” so I would of had to wrap it in, So it worked out even better with the core there and now it’s crazy strong without any glass over it yet!
    glued in with 2:1 epoxy and woven roven/1708 FB
    video: https://youtu.be/jCEdR5DoPto
ID:	499814Click image for larger version.
ID:	499815Click image for larger version.
ID:	499816Click image for larger version.
ID:	499817Click image for larger version.
ID:	499819Click image for larger version.
ID:	499820Click image for larger version.
ID:	499821Click image for larger version.
  23. Likes LakeFever liked this post
  1. Hydrostream VooDoo
    By Coonass2020 in forum Hulls Wanted
    Last Post: 08-31-2021, 03:55 PM
  2. One of a kind Hydrostream Voodoo?
    By shane65 in forum Ebay Listings and Other Internet Listings
    Last Post: 05-20-2021, 08:19 AM
  3. 13' Hydrostream VooDoo
    By 89LASER in forum Ebay Listings and Other Internet Listings
    Last Post: 04-29-2020, 01:44 PM
  4. Hydrostream Voodoo
    By Voodoo in forum Technical Discussion
    Last Post: 04-19-2010, 07:15 PM
